I am using an Arduino Mega 2560 with a 2.4GHz transmitter/receiver with a common ground. The Mega and my receiver/servos are powered independently.
I am trying to place servos into different groups so that when I move a particular pot on my R/C transmitter it moves those servos at the same time. When I move a different pot it moves a different group of servos.
The below does not work, however, it shows what I am trying to achieve:
#include <VarSpeedServo.h>
const int numberOfServos = 2; //number of servos
VarSpeedServo servo[numberOfServos]; //create servo objects
int portNumberGroup1[numberOfServos] = {22}; //initalize input pin numbers
int portNumberGroup2[numberOfServos] = {23}; //initalize input pin numbers
int servoPinGroup1[numberOfServos] = {52}; //intialize output pins servos connect to
int servoPinGroup2[numberOfServos] = {53}; //intialize output pins servos connect to
int highvalue[numberOfServos] = {1600}; //control knob value high
int lowvalue[numberOfServos] = {1100}; //control knob value low
int closepos = {45}; //value (in degrees) for servo closed position value
int openpos = {80}; //value (in degrees) for servo open postion
int mid = 90; //value (in degrees) for servo mid postion
for (int i = 0; i < numberOfServos; i++)
servo[i].attach(servoPinGroup1[i]); // attach servos to output pins
servo[i].attach(servoPinGroup2[i]); // attach servos to output pins
pinMode (portNumberGroup1[i], INPUT); //set up input pins
pinMode (portNumberGroup2[i], INPUT); //set up input pins
void loop ()
for (int i = 0; i < numberOfServos; i++) {
if (pulseIn(portNumberGroup1[i],HIGH) > lowvalue[i]) //read all inputs and outputs servo.move commands
servo[i].slowmove (openpos, 5); // second arg is servo speed , 20 is about 3 seconds
servo[i].slowmove (closepos, 5); // second arg is servo speed , 20 is about 3 seconds
if (pulseIn(portNumberGroup2[i],HIGH) > lowvalue[i]) //read all inputs and outputs servo.move commands
servo[i].slowmove (openpos, 10); // second arg is servo speed , 20 is about 3 seconds
servo[i].slowmove (closepos, 10); // second arg is servo speed , 20 is about 3 seconds
The below works, however, this does not allow me to put servos into different groups to perform different movements depending on what pot on the controller I turn:
int portNumber[numberOfServos] = {22,21,20}; //initalize input pin numbers
int servoPin[numberOfServos] = {52,51,50}; //intialize output pins servos connect to
servo[i].attach(servoPin[i]); // attach servos to output pins
pinMode (portNumber[i], INPUT); //set up input pins
void loop ()
if (pulseIn(portNumber[i],HIGH) > lowvalue[i]) //read all inputs and outputs servo.move commands
If I initialize all the servos then how do I next go about placing them into groups to associate with different pins on the Mega which are connected to my receiver?
Assuming there is one group of servos for each receiver channel of interest and all of the servos in a group are connected to the same output pin:
// Receiver channels
const int CHANNELS = 3;
const int ChannelPins[CHANNELS] = {22, 21, 20}; //initalize input pin numbers
const int CHANNEL_MAX = {1600}; //control knob value max (microseconds)
const int CHANNEL_MIN = {1100}; //control knob value min (microseconds)
// Output Servos
const int SERVOGROUPS = CHANNELS; //number of servo groups
VarSpeedServo ServoGroups[CHANNELS]; //create servo objects
const int ServoGroupPins[CHANNELS] = {52, 51, 50}; //intialize output pins servos connect to
const int SERVO_CLOSE = 45; //value (in degrees) for servo closed position value
const int SERVO_OPEN = 80; //value (in degrees) for servo open postion
const int SERVO_MIDDLE = 90; //value (in degrees) for servo mid postion
for (int i = 0; i < CHANNELS; i++) {
pinMode (ChannelPins[i], INPUT); //set up input pins
ServoGroups[i].attach(ServoGroupPins[i]); // attach servos to output pins
void loop () {
int channelValue = pulseIn(ChannelPins[i], HIGH);
int servoPosition = map(channelValue, CHANNEL_MIN, CHANNEL_MAX, SERVO_OPEN, SERVO_CLOSE);
ServoGroups[i].slowmove(servoPosition, 5);
I’m not sure that’s what was asked for.
I read it as an input channel could fan-out to multiple servos - you’d need a second, nested for loop for the group, I think.
Neither am I, which is why I stated my assumptions at the top. I'm not even sure that the OP knows what he or she was asking for.
Yes, you could connect each servo to a separate output pin and add arrays to associate servo pins with groups and groups with input channels but since each group can use a single output pin it doesn't really make sense to use separate pins.
I would like to be able to operate a group of servos, for example, on channel 3 (all connected to the same signal pin on the Mega, i.e. 22) to perform a certain movement, however, have another group of servos on channel 4 to perform a different movement connected to signal pin 23.
In the example that John posted (thank you), can I not add more channels which would be my servo groups?
tom_tom_go:
Yes. You can add more channel input pins and servo output pins as long as you add them together. I don't know about the VarSpeedServo library but the standard Servo library can support 48 servo outputs on the Arduino Mega. I doubt that your RF receiver has 48 channels but you can have more than one receiver.
But how do I get different channels to use different loops because CHANNELS is set to all pins which would mean the servos still all follow the same command?
For example, I want to have two or loops that perform different movements but only certain servos use one loop while other use the other loop:
void loop () {
void loop () {
ServoGroups[i].slowmove(servoPosition, 20);
You want different groups of servos to run at different speeds? Easy:
const int CHANNEL_MAX = 1600; //control knob value max (microseconds)
const int CHANNEL_MIN = 1100; //control knob value min (microseconds)
// Output Servos
const int ServoGroupSpeeds[CHANNELS] = {5, 20, 15};
void loop () {
ServoGroups[i].slowmove(servoPosition, ServoGroupSpeeds[i]);
