Hi all. I am looking for guidance and tips for the following project that I want to run:
I am getting a coffee plant in a plant pot that will be grown indoors and not in its natural climate.
I have an Arduino Uno (have to check which version when I get home) that I want to use in order to keep track and possibly alter all environmental conditions required to keep the plant alive.
I would like to be able to monitor the plant online as well.
So far I have gathered that I will need the following:
- DHT11 Temperature and Humidity Sensor
- Capacitive Soil Moisture sensor
- BH1750 light sensor
- Relay module for watering, humidifying, grow light, etc
- Water pump
- Assuming I have a wifi Uno, do I still need something else like IOT connection?
I am sure that I probably need a lot more than the above for total control/access of all the data that I want.
This plant has a lot of sentimental value for me, and I therefore don’t mind spending an understandable amount to keep it alive.
Please let me know what I am missing and or guidance to get the project up and running.
Much appreciated!
What climate do you have in your house and what climate does the plant need?
I.e. maybe your house is more humid tgan good for the plant. In that case you need a dehumidifier...
Will you test your setup on a less special (to you) plant?
Should I rather go for a different type if these don’t work so well?
The plant needs warm and humid temperatures, and not big fluctuations either.
I have a warm and mostly dry humidity house, it may even get too hot - so I will need to make a plan with that. I can put a humidifier in the room.
I agree with your statement.
Definitely not a good first project.
I will start off with just reading data from the sensors for manual manipulation (watering, light, etc).
Thus using the data to assist me. Chances are probably quite high that the plant won’t survive, I am honestly just trying my best to possibly keep it alive for as long as possible.
If it survives I will move on to automation in due time.
Otherwise, when it dies, I will play with the idea on other plants further on.
Hello rabbidt7
Welcome back
My recommendation from practice:
Start with individual software modules that can operate the interfaces to the sensors and actuators listed above.
After a successful tests, these software modules can be soldered together to form the overall project using a suitable control structure.
hth
