Plant Health Monitoring Using Camera Pink farming
Hey,
i'm trying to build a vertical farm scale model (pink light farming) , and i want to add a camera to monitor the plants health using NDVI , beside the sensors i'll need like temperature, humidity, PH ... etc
i'm newbie to these topics, so what is your recommendation for sensors i should use and the camera and the library for it.
Thanks
ESP32 has a camera.
Search what is being done in the Camera part separate from the temperature humidity level sensors.
The arduino can do those really well
Arduino
BMR280 temperature humidity
DS18B20 temperature submerged
Float levlevel sensors
Depending on your pumps
Cheap relays
SSR 30 amp rerlays
To get started
You can get these working in hours
The raspberry pi may be a better choice for the processing of the images due the larger processor
