So I am revisiting the plant watering project, I have run various projects in the past, I had a couple of basil plants thriving for several years before indoors and eventually had a cloud setup but I want to streamline, I have some questions about approach
yesterday I set up with the Nano RP2040 Connect and was having issues with power (relay and pump) eventually I attempted to smooth the supply and because of aging eyes and small connections I let the magic smoke out, the board no longer wants to connect so I guess thats that.
I do not have any more nano's but I do have a few MKR Wifi1010's and I have a relay shield. My question is what is your preferred method of powering these? I really only have one wall socket available to me so would like to use a 240v-5v 2amp supply for the pump through a relay and the board without having it drop connection due to power spikes etc
has anyone used this shield? how did you power the project?
the shield is here its for the MKR not Nano, yes it runs off 3.3v, it has a proto area where I can add a power jack and MOSFET etc, it would have been nice if it actually came with options for power. I did look briefly for a power supply that has a 6.5mm jack and USB, will have another google today
as you say the relay board is designed to accept a MKR board
however, the MKR boards uses 3.3V logic as the Nano rp2040 so the nano should be able to drive the relays
have a look at MKRRelayShield_V4.0 schematic
the relays are connected to pins 1 (CMD1) and 2 (CMD2)
power the relay board via its +3.3V and GND pins or screw terminals from the Nano RP2040 +3.3V and GND
implement a simple program to check the RP2040 can switch the relays
note the maximum relay ratings
Max. operating voltage: 24 VAC, 50 VDC
Max. operating current: 1 A
Max. switching capacity: 62.50 VA, 30W
if you are planning to switch any load greater than 1amp (in particular if an inductive load) use an external contactor
managed to misread post 1 !
thought you were connecting the Rp2040 to the relay shield but I see you are plugging a MKR1010 into it
should be no problem powering the MKR/relay board and pumps etc from the multi-port-USB wall socket
the MKR1010 would operate the relays via pins 1 and 2
I would like to see a shield with split power from one source, I have faced this a few times with projects, used MOSFETs and capacitors etc but its a fiddly old game and my eyes, although not really bad they do make it challenging, I am becoming much more of a plug and play type
