I'm new here, and one of the projects I'm thinking about is a system to water potted plants. I haven't ordered any parts yet.
I was thinking about putting a soil probe in the flowerpot and having an elevated cistern. The soil probe would tell a board when that pot needed to be watered, then the board would open a valve at the bottom of the cistern, and a flow meter would report back the flow rate so that the board could shut the valve when a certain amount of water had passed through. Probably not the most efficient way of getting the job done, but I would be able to apply some concepts to another project I have in mind.
If that sounds good, I was hoping I could get some opinions/advice about some hardware I was looking at.
What I'm not seeing is people talking about is this: http://www.seeedstudio.com/depot/electric-solenoid-valve-p-636.html
It looks like it could be used in this application, I like it because it is inexpensive, but I don't see examples of it being used with arduino boards. Did I abandon my search too soon, or not look very hard? Can any give or cite examples of this being used with arduino boards? Perhaps there is something else out there like this that would be a better fit for this type of project?
Electrically that valve will work, however one problem with most solenoid valves is that they need pressure to crack, a simple gravity feed from a header tank won't cut it.
Hmm, I really don't know. That's about 3-116psi and it may refer to the min pressure required to hold it open (3) and the max it can handle (116).
Whether or not the pressure needed to crack it is somewhere between these values I don't know. I have been caught with this before though when using a different type of solenoid valve.
just a question: that fritzing image isn't correct, is it? the ground is not connected and the signal is connected to the Vcc, which is rather strange..
i think they misundertood the lay-out of the breadboard xs
Kent88:
... Probably not the most efficient way of getting the job done, but I would be able to apply some concepts to another project I have in mind...
I'm afraid I'm going to be stubborn on the design. The specific parts, though, are up for debate.
