Hi people, noob is here.
I've bought a PM2.5 sensor and failed to connect it to arduino. There are 10 pins (5x2), I've tried to connect each pin with separate wire from my Arduino Kit, but pins are too small. The size of connector is 5.5x1.5 mm (from left to right pin, from top to bottom pin). Is it some common type of connector? Or should I look for an adapter for this specific sensor?
All the pictures I have found also show the connector cable and some kind of little circuit board. If your device did not come with the cable, contact the seller.
Paul
Looks like most of them are sold with adapters, but my specific was w/o it intentionally.
Found a separate adapter here https://www.aliexpress.com/item/33021508840.html
