PlatformionIO Problem Code Bulding
Hi ich habe Problem ich wollt diese Projekt machen GitHub - mzashh/HUB75-Pixel-Art-Display: A WIFI enabled LED Pixel Art Display based on HUB75 panels driven by the ESP32
PlatformionIO
Ich habe die Libraries
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/.pio/libdeps/nodemcu-32s
Kopiert und
main.cpp
webpages.h
webserver.ino
sind in /home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src
Wenn ich den Code Build kommt diese Wall auf Text
*  Executing task in folder HUB75-Pixel-Art-Display: platformio run
Processing nodemcu-32s (platform: espressif32; board: nodemcu-32s; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/nodemcu-32s.html
PLATFORM: Espressif 32 (6.10.0) > NodeMCU-32S
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
 - framework-arduinoespressif32 @ 3.20017.241212+sha.dcc1105b
 - tool-esptoolpy @ 1.40501.0 (4.5.1)
 - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Converting webserver.ino
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 40 compatible libraries
Scanning dependencies...
Dependency Graph
|-- AnimatedGIF @ 2.2.0
|-- AsyncTCP @ 3.4.2
|-- ESP32 HUB75 LED MATRIX PANEL DMA Display @ 3.0.12
|-- ESPAsyncWebServer @ 3.7.7
|-- GFX_Lite @ 1.0.0
|-- LittleFS @ 2.0.0
|-- WiFi @ 2.0.0
Building in release mode
Compiling .pio/build/nodemcu-32s/src/main.cpp.o
Compiling .pio/build/nodemcu-32s/src/webserver.ino.cpp.o
In file included from src/main.cpp:9:
.pio/libdeps/nodemcu-32s/ESP32-HUB75-MatrixPanel-DMA-master/src/ESP32-HUB75-MatrixPanel-I2S-DMA.h:19:12: fatal error: Adafruit_GFX.h: No such file or directory
* Looking for Adafruit_GFX.h dependency? Check our library registry!
* CLI  > platformio lib search "header:Adafruit_GFX.h"
* Web  > https://registry.platformio.org/search?q=header:Adafruit_GFX.h
   #include "Adafruit_GFX.h" // Adafruit class with all the other stuff
compilation terminated.
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:3:15: error: variable or field 'notFound' declared void
 String processor(const String& var) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:3:15: error: 'AsyncWebServerRequest' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:3:38: error: 'request' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:3:38: note: suggested alternative: 'renameat'
                                      renameat
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:4:23: error: 'AsyncWebServerRequest' was not declared in this scope
   if (var == "FIRMWARE") {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:4:47: error: 'request' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:4:47: note: suggested alternative: 'renameat'
                                               renameat
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:19: error: variable or field 'handleUpload' declared void
     return FIRMWARE_VERSION;
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:19: error: 'AsyncWebServerRequest' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:42: error: 'request' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:42: note: suggested alternative: 'renameat'
                                          renameat
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:58: error: expected primary-expression before 'filename'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:75: error: expected primary-expression before 'index'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:90: error: expected primary-expression before '*' token
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:91: error: 'data' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:91: note: suggested alternative: 'atan'
        atan
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:104: error: expected primary-expression before 'len'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:109: error: expected primary-expression before 'bool'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino: In function 'String processor(const String&)':
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:12: error: 'FIRMWARE_VERSION' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:5:12: note: suggested alternative: 'ESP_IDF_VERSION'
            ESP_IDF_VERSION
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:9:31: error: 'LittleFS' was not declared in this scope
     return humanReadableSize((LittleFS.totalBytes() - LittleFS.usedBytes()));
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:9:31: note: suggested alternative: 'bitClear'
                               bitClear
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:9:12: error: 'humanReadableSize' was not declared in this scope
Compiling .pio/build/nodemcu-32s/lib204/GFX_Lite-main/GFX_Lite.cpp.o
*** [.pio/build/nodemcu-32s/src/main.cpp.o] Error 1
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:13:30: error: 'LittleFS' was not declared in this scope
     return humanReadableSize(LittleFS.usedBytes());
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:13:30: note: suggested alternative: 'bitClear'
                              bitClear
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:13:12: error: 'humanReadableSize' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:17:30: error: 'LittleFS' was not declared in this scope
     return humanReadableSize(LittleFS.totalBytes());
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:17:30: note: suggested alternative: 'bitClear'
                              bitClear
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:17:12: error: 'humanReadableSize' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:21:12: error: 'sliderValue' was not declared in this scope
     return sliderValue;
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino: In function 'void configureWebServer()':
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:30:3: error: 'server' was not declared in this scope
   server->onNotFound(notFound);
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:30:3: note: suggested alternative: 'Server'
   Server
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:30:22: error: 'notFound' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:30:22: note: suggested alternative: 'noTone'
                      noTone
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:33:24: error: 'handleUpload' was not declared in this scope
   server->onFileUpload(handleUpload);
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:36:25: error: 'HTTP_GET' was not declared in this scope
   server->on("/logout", HTTP_GET, [](AsyncWebServerRequest * request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:36:25: note: suggested alternative: 'DST_MET'
                         DST_MET
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:36:38: error: 'AsyncWebServerRequest' has not been declared
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino: In lambda function:
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:37:14: error: request for member 'requestAuthentication' in '* request', which is of non-class type 'int'
     request->requestAuthentication();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:38:14: error: request for member 'send' in '* request', which is of non-class type 'int'
     request->send(401);
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:42:42: error: 'AsyncWebServerRequest' has not been declared
   server->on("/logged-out", HTTP_GET, [](AsyncWebServerRequest * request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:43:46: error: request for member 'client' in '* request', which is of non-class type 'int'
     String logmessage = "Client:" + request->client()->remoteIP().toString() + " " + request->url();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:43:95: error: request for member 'url' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:45:14: error: request for member 'send_P' in '* request', which is of non-class type 'int'
     request->send_P(401, "text/html", logout_html, processor);
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:45:39: error: 'logout_html' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:48:32: error: 'AsyncWebServerRequest' has not been declared
   server->on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:49:46: error: request for member 'client' in '* request', which is of non-class type 'int'
     String logmessage = "Client:" + request->client()->remoteIP().toString() + + " " + request->url();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:49:97: error: request for member 'url' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:51:33: error: 'checkUserWebAuth' cannot be used as a function
     if (checkUserWebAuth(request)) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:54:16: error: request for member 'send_P' in '* request', which is of non-class type 'int'
       request->send_P(200, "text/html", index_html, processor);
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:54:41: error: 'index_html' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:54:41: note: suggested alternative: 'index'
                                         index
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:58:23: error: request for member 'requestAuthentication' in '* request', which is of non-class type 'int'
       return request->requestAuthentication();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:63:44: error: 'AsyncWebServerRequest' has not been declared
        server->on("/slider", HTTP_GET, [] (AsyncWebServerRequest *request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:66:18: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
     if (request->hasParam(PARAM_INPUT)) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:66:27: error: 'PARAM_INPUT' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:66:27: note: suggested alternative: 'MAX_INPUT'
                           MAX_INPUT
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:67:31: error: request for member 'getParam' in '* request', which is of non-class type 'int'
       inputMessage = request->getParam(PARAM_INPUT)->value();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:68:7: error: 'sliderValue' was not declared in this scope
       sliderValue = inputMessage;
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:69:7: error: 'dma_display' was not declared in this scope
       dma_display->setBrightness8(sliderValue.toInt());
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:77:38: error: 'AsyncWebServerRequest' has not been declared
   server->on("/reboot", HTTP_GET, [](AsyncWebServerRequest * request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:78:46: error: request for member 'client' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:78:95: error: request for member 'url' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:80:33: error: 'checkUserWebAuth' cannot be used as a function
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:81:16: error: request for member 'send' in '* request', which is of non-class type 'int'
       request->send(200, "text/html", reboot_html);
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:81:39: error: 'reboot_html' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:85:7: error: 'shouldReboot' was not declared in this scope
       shouldReboot = true;
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:89:23: error: request for member 'requestAuthentication' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:93:41: error: 'AsyncWebServerRequest' has not been declared
   server->on("/listfiles", HTTP_GET, [](AsyncWebServerRequest *request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:94:46: error: request for member 'client' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:94:95: error: request for member 'url' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:95:33: error: 'checkUserWebAuth' cannot be used as a function
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:98:18: error: request for member 'send' in '* request', which is of non-class type 'int'
         request->send(200, "text/plain", listFiles(true, 1, maxGIFsPerPage)); // Explicitly pass page and pageSize
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:98:61: error: 'maxGIFsPerPage' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:98:42: error: 'listFiles' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:98:42: note: suggested alternative: 'lutimes'
                                          lutimes
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:102:25: error: request for member 'requestAuthentication' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:106:36: error: 'AsyncWebServerRequest' has not been declared
   server->on("/list", HTTP_GET, [](AsyncWebServerRequest *request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:108:18: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
     if (request->hasParam("page")) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:109:25: error: request for member 'getParam' in '* request', which is of non-class type 'int'
         page = request->getParam("page")->value().toInt();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:114:45: error: 'maxGIFsPerPage' was not declared in this scope
     String fileList = listFiles(true, page, maxGIFsPerPage); // Generate the table content
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:114:23: error: 'listFiles' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:114:23: note: suggested alternative: 'lutimes'
                       lutimes
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:115:14: error: request for member 'send' in '* request', which is of non-class type 'int'
     request->send(200, "text/html", fileList);
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:119:40: error: 'AsyncWebServerRequest' has not been declared
   server->on("/setColor", HTTP_GET, [](AsyncWebServerRequest *request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:120:18: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
     if (request->hasParam("r") && request->hasParam("g") && request->hasParam("b")) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:120:44: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:120:70: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:121:9: error: 'colorR' was not declared in this scope
         colorR = request->getParam("r")->value().toInt();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:121:9: note: suggested alternative: 'close'
         close
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:121:27: error: request for member 'getParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:122:9: error: 'colorG' was not declared in this scope
         colorG = request->getParam("g")->value().toInt();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:122:9: note: suggested alternative: 'close'
         close
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:122:27: error: request for member 'getParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:123:9: error: 'colorB' was not declared in this scope
         colorB = request->getParam("b")->value().toInt();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:123:9: note: suggested alternative: 'close'
         close
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:123:27: error: request for member 'getParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:127:18: error: request for member 'send' in '* request', which is of non-class type 'int'
         request->send(200, "text/plain", "Color updated");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:129:18: error: request for member 'send' in '* request', which is of non-class type 'int'
         request->send(400, "text/plain", "Missing parameters");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:133:41: error: 'AsyncWebServerRequest' has not been declared
   server->on("/toggleGIF", HTTP_GET, [](AsyncWebServerRequest *request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:134:18: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
     if (request->hasParam("state")) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:135:33: error: request for member 'getParam' in '* request', which is of non-class type 'int'
         String state = request->getParam("state")->value();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:136:9: error: 'gifEnabled' was not declared in this scope
         gifEnabled = (state == "on"); // Update the gifEnabled variable
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:136:9: note: suggested alternative: 'spiSSEnable'
         spiSSEnable
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:138:18: error: request for member 'send' in '* request', which is of non-class type 'int'
         request->send(200, "text/plain", "GIF playback state updated");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:140:18: error: request for member 'send' in '* request', which is of non-class type 'int'
         request->send(400, "text/plain", "Missing 'state' parameter");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:144:44: error: 'AsyncWebServerRequest' has not been declared
  server->on("/toggleLoopGif", HTTP_GET, [](AsyncWebServerRequest *request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:145:16: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:146:31: error: request for member 'getParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:147:7: error: 'loopGifEnabled' was not declared in this scope
       loopGifEnabled = (state == "on");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:147:7: note: suggested alternative: 'spiSSEnable'
       spiSSEnable
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:149:16: error: request for member 'send' in '* request', which is of non-class type 'int'
       request->send(200, "text/plain", "Loop GIF state updated");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:151:16: error: request for member 'send' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:155:42: error: 'AsyncWebServerRequest' has not been declared
  server->on("/toggleClock", HTTP_GET, [](AsyncWebServerRequest *request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:156:16: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:157:31: error: request for member 'getParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:158:7: error: 'clockEnabled' was not declared in this scope
       clockEnabled = (state == "on");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:158:7: note: suggested alternative: 'clock_nanosleep'
       clock_nanosleep
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:160:11: error: 'scrollTextEnabled' was not declared in this scope
           scrollTextEnabled = false; // Disable scrolling text if the clock is enabled
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:163:16: error: request for member 'send' in '* request', which is of non-class type 'int'
       request->send(200, "text/plain", "Clock state updated");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:165:16: error: request for member 'send' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:169:46: error: 'AsyncWebServerRequest' has not been declared
 server->on("/toggleScrollText", HTTP_GET, [](AsyncWebServerRequest *request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:170:16: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:171:31: error: request for member 'getParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:172:7: error: 'scrollTextEnabled' was not declared in this scope
       scrollTextEnabled = (state == "on");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:174:11: error: 'clockEnabled' was not declared in this scope
           clockEnabled = false; // Disable the clock if scrolling text is enabled
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:174:11: note: suggested alternative: 'clock_nanosleep'
           clock_nanosleep
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:177:16: error: request for member 'send' in '* request', which is of non-class type 'int'
       request->send(200, "text/plain", "Scrolling text state updated");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:179:16: error: request for member 'send' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:183:48: error: 'AsyncWebServerRequest' has not been declared
   server->on("/updateScrollText", HTTP_GET, [](AsyncWebServerRequest *request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:184:18: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
     if (request->hasParam("text") && request->hasParam("fontSize") && request->hasParam("speed")) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:184:47: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:184:80: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:185:9: error: 'scrollText' was not declared in this scope
         scrollText = request->getParam("text")->value();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:185:31: error: request for member 'getParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:186:9: error: 'scrollFontSize' was not declared in this scope
         scrollFontSize = request->getParam("fontSize")->value().toInt();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:186:35: error: request for member 'getParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:187:9: error: 'scrollSpeed' was not declared in this scope
         scrollSpeed = request->getParam("speed")->value().toInt();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:187:32: error: request for member 'getParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:189:18: error: request for member 'send' in '* request', which is of non-class type 'int'
         request->send(200, "text/plain", "Scrolling text updated");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:191:18: error: request for member 'send' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:195:36: error: 'AsyncWebServerRequest' has not been declared
   server->on("/file", HTTP_GET, [](AsyncWebServerRequest * request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:196:46: error: request for member 'client' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:196:95: error: request for member 'url' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:197:33: error: 'checkUserWebAuth' cannot be used as a function
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:201:20: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
       if (request->hasParam("name") && request->hasParam("action")) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:201:49: error: request for member 'hasParam' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:202:47: error: request for member 'getParam' in '* request', which is of non-class type 'int'
         String fileName = "/"+String(request->getParam("name")->value() );
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:203:43: error: request for member 'getParam' in '* request', which is of non-class type 'int'
         const char *fileAction = request->getParam("action")->value().c_str();
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:205:43: error: request for member 'client' in '* request', which is of non-class type 'int'
         logmessage = "Client:" + request->client()->remoteIP().toString() + " " + request->url() + "?name=" + String(fileName) + "&action=" + String(fileAction);
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:205:92: error: request for member 'url' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:207:14: error: 'LittleFS' was not declared in this scope
         if (!LittleFS.exists(fileName)) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:207:14: note: suggested alternative: 'bitClear'
              bitClear
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:209:20: error: request for member 'send' in '* request', which is of non-class type 'int'
           request->send(400, "text/plain", "ERROR: file does not exist");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:215:22: error: request for member 'send' in '* request', which is of non-class type 'int'
             request->send(LittleFS, fileName, "application/octet-stream");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:219:22: error: request for member 'send' in '* request', which is of non-class type 'int'
             request->send(200, "text/plain", "Deleted File: " + String(fileName));
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:222:13: error: 'requestedGifPath' was not declared in this scope
             requestedGifPath = fileName; // Store the requested GIF path
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:225:13: error: 'gifFile' was not declared in this scope
             gifFile = FILESYSTEM.open(fileName);
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:225:23: error: 'FILESYSTEM' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:231:22: error: request for member 'send' in '* request', which is of non-class type 'int'
             request->send(LittleFS, fileName, "image/gif");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:235:22: error: request for member 'send' in '* request', which is of non-class type 'int'
             request->send(400, "text/plain", "ERROR: invalid action param supplied");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:240:18: error: request for member 'send' in '* request', which is of non-class type 'int'
         request->send(400, "text/plain", "ERROR: name and action params required");
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:245:23: error: request for member 'requestAuthentication' in '* request', which is of non-class type 'int'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino: At global scope:
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:250:15: error: variable or field 'notFound' declared void
 void notFound(AsyncWebServerRequest *request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:250:15: error: 'AsyncWebServerRequest' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:250:38: error: 'request' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:250:38: note: suggested alternative: 'renameat'
                                      renameat
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:257:23: error: redefinition of 'bool checkUserWebAuth'
 bool checkUserWebAuth(AsyncWebServerRequest * request) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:4:6: note: 'bool checkUserWebAuth' previously defined here
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:257:23: error: 'AsyncWebServerRequest' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:257:47: error: 'request' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:257:47: note: suggested alternative: 'renameat'
                                               renameat
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:268:19: error: variable or field 'handleUpload' declared void
 void handleUpload(AsyncWebServerRequest *request, String filename, size_t index, uint8_t *data, size_t len, bool final) {
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:268:19: error: 'AsyncWebServerRequest' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:268:42: error: 'request' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:268:42: note: suggested alternative: 'renameat'
                                          renameat
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:268:58: error: expected primary-expression before 'filename'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:268:75: error: expected primary-expression before 'index'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:268:90: error: expected primary-expression before '*' token
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:268:91: error: 'data' was not declared in this scope
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:268:91: note: suggested alternative: 'atan'
        atan
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:268:104: error: expected primary-expression before 'len'
/home/sascha/Dokumente/PlatformIO/Projects/HUB75-Pixel-Art-Display/src/webserver.ino:268:109: error: expected primary-expression before 'bool'
*** [.pio/build/nodemcu-32s/src/webserver.ino.cpp.o] Error 1
========================================================================== [FAILED] Took 2.85 seconds ==========================================================================
 *  The terminal process "platformio 'run'" terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
Code
#include <Arduino.h>
//By mzashh https://github.com/mzashh
#define FIRMWARE_VERSION "v0.4.5b"
#define FILESYSTEM LittleFS
#include <LittleFS.h>
#include <AnimatedGIF.h>
#include <ESP32-HUB75-MatrixPanel-I2S-DMA.h>
#include <WiFi.h>
#include <AsyncTCP.h>
#include <GFX_Layer.hpp>
#include <ESPAsyncWebServer.h>
#include "webpages.h"
#include "time.h"
#define A_PIN   22
#define B_PIN   32
#define C_PIN   33
#define D_PIN   17
#define E_PIN   21
#define PANEL_RES_X 64
#define PANEL_RES_Y 64
#define PANEL_CHAIN 1
MatrixPanel_I2S_DMA *dma_display = nullptr;
uint16_t myBLACK = dma_display->color565(0, 0, 0);
uint16_t myWHITE = dma_display->color565(255, 255, 255);
uint16_t myRED = dma_display->color565(255, 0, 0);
uint16_t myGREEN = dma_display->color565(0, 255, 0);
uint16_t myBLUE = dma_display->color565(0, 0, 255);
uint16_t textWidth = 0; // Width of the scrolling text
uint16_t w, h;
uint8_t colorR = 255; // Default Red value
uint8_t colorG = 255; // Default Green value
uint8_t colorB = 255; // Default Blue value
uint8_t scrollFontSize = 2; // Default font size (1 = small, 2 = normal, 3 = big, 4 = huge)
uint8_t scrollSpeed = 18;   // Default scroll speed (1 = fastest, 150 = slowest)
int16_t xOne, yOne;
const String default_ssid = "Pyka"; // Your WiFi SSID
const String default_wifipassword = "N*8fWx.Y3+k"; // Your WiFi password
const String default_httpuser = "admin"; // WebUI login id
const String default_httppassword = "admin"; // WebUI login password
const int default_webserverporthttp = 80;
const char* ntpServer = "pool.ntp.org"; // NTP server
const char* PARAM_INPUT = "value";
const long  gmtOffset_sec = 0; // GMT Timezone Offset in seconds (change this to your own)
const int   daylightOffset_sec = 0;
const int maxGIFsPerPage = 4; // Change this value to set the maximum number of GIFs per page (keep this at 4)
int textXPosition = 64;  // Will start off screen
int textYPosition = 24;  // center of screen (half of the text height)
unsigned long lastPixelToggle = 0; // Tracks the last time the second set of pixels was drawn
unsigned long lastScrollUpdate = 0; // Tracks the last time the text was scrolled
unsigned long isAnimationDue;
bool showFirstSet = true; // Default state: Clock divider colon
bool clockEnabled = true; // Default state: Clock is enabled
bool gifEnabled = true; // Default state: GIF playback is enabled
bool scrollTextEnabled = false; // Default state: Scrolling text is disabled
bool loopGifEnabled = true; // Default state: Loop GIF is enabled (reverese logic)
String inputMessage;
String sliderValue = "255"; //Default brightness value
String scrollText = "Hello"; // Default Text String
String currentGifPath = ""; // Store the current GIF file path
String requestedGifPath = ""; // Path of the GIF requested by the user
struct Config {
String ssid;               // wifi ssid
String wifipassword;       // wifi password
String httpuser;           // username to access web admin
String httppassword;       // password to access web admin
int webserverporthttp;     // http port number for web admin
 Config config;              // configuration
 bool shouldReboot = false; // schedule a reboot
 AsyncWebServer *server;   // initialise webserver
// function defaults
 String listFiles(bool ishtml = false);
 AnimatedGIF gif;
 File f;
 int x_offset, y_offset;
 void layer_draw_callback(int16_t x, int16_t y, uint8_t r_data, uint8_t g_data, uint8_t b_data) {
  dma_display->drawPixel(x,y, dma_display->color565(r_data,g_data,b_data));
// Global GFX_Layer object
GFX_Layer gfx_layer_bg(64, 64, layer_draw_callback); // background
GFX_Layer gfx_layer_fg(64, 64, layer_draw_callback); // foreground
GFX_LayerCompositor gfx_compositor(layer_draw_callback);
void GIFDraw(GIFDRAW *pDraw)
    uint8_t *s;
    uint16_t *d, *usPalette, usTemp[320];
    int x, y, iWidth;
  iWidth = pDraw->iWidth;
  if (iWidth > MATRIX_WIDTH)
      iWidth = MATRIX_WIDTH;
    usPalette = pDraw->pPalette;
    y = pDraw->iY + pDraw->y; // current line
    s = pDraw->pPixels;
    if (pDraw->ucDisposalMethod == 2) // restore to background color
      for (x=0; x<iWidth; x++)
        if (s[x] == pDraw->ucTransparent)
           s[x] = pDraw->ucBackground;
      pDraw->ucHasTransparency = 0;
    if (gifEnabled) // Check if GIF playback is enabled
    if (pDraw->ucHasTransparency) // if transparency used
      uint8_t *pEnd, c, ucTransparent = pDraw->ucTransparent;
      int x, iCount;
      pEnd = s + pDraw->iWidth;
      x = 0;
      iCount = 0; // count non-transparent pixels
      while(x < pDraw->iWidth)
        c = ucTransparent-1;
        d = usTemp;
        while (c != ucTransparent && s < pEnd)
          c = *s++;
          if (c == ucTransparent) // done, stop
            s--; // back up to treat it like transparent
          else // opaque
             *d++ = usPalette[c];
             iCount++;
        } // while looking for opaque pixels
        if (iCount) // any opaque pixels?
          for(int xOffset = 0; xOffset < iCount; xOffset++ ){
            gfx_layer_bg.drawPixel(x + xOffset, y, usTemp[xOffset]); // 565 Color Format
          x += iCount;
          iCount = 0;
        // no, look for a run of transparent pixels
        c = ucTransparent;
        while (c == ucTransparent && s < pEnd)
          c = *s++;
             iCount++;
             s--;
        if (iCount)
          x += iCount; // skip these
          iCount = 0;
    else // does not have transparency
      s = pDraw->pPixels;
      // Translate the 8-bit pixels through the RGB565 palette (already byte reversed)
      for (x=0; x<pDraw->iWidth; x++)
        gfx_layer_bg.drawPixel(x, y, usPalette[*s++]); // color 565
      gfx_layer_bg.clear(); // Clear the background layer if GIF playback is disabled
    if (clockEnabled) {
    // Request Time from internal RTC
    struct tm timeinfo;
    //getLocalTime(&timeinfo);
    if(!getLocalTime(&timeinfo)){
      Serial.println("Failed to obtain time");
    // Display the time in the format HH:MM (12/24H)
    gfx_layer_fg.clear();
    gfx_layer_fg.setTextColor(gfx_layer_fg.color565(colorR, colorG, colorB));
    gfx_layer_fg.setTextSize(2);
    gfx_layer_fg.setCursor(7, 24);
    //gfx_layer_fg.print(&timeinfo, "%H"); // print Hours from NTP 24 Hour format (Uncomment this for 24H time vice versa for 12H)
    gfx_layer_fg.print(&timeinfo, "%I"); // print Hours from NTP 12 Hour format (Comment this out if you want 24H time vice versa for 12H)
    gfx_layer_fg.setCursor(35, 24);
    gfx_layer_fg.print(&timeinfo, "%M"); // print Minutes from NTP
    // Draw the hh:mm divider
    if (millis() - lastPixelToggle >= 1000) // Check if one second has passed
      showFirstSet = !showFirstSet; // Toggle between the first and second set of pixels
      lastPixelToggle = millis(); // Reset the timer
  if (showFirstSet) {
    // Active pixels
    gfx_layer_fg.setTextSize(1);
    gfx_layer_fg.setCursor(28, 28);
    gfx_layer_fg.print(".");
    gfx_layer_fg.setCursor(28, 22);
    // Dark pixels
    gfx_layer_fg.setTextColor(gfx_layer_fg.color565(0, 0, 0));
  else {
    // Clear the clock display if the clock is disabled
if (scrollTextEnabled) {
  //gfx_layer_fg.clear(); // Clear the foreground layer
  gfx_layer_fg.setTextWrap(false); // Disable text wrapping
if (scrollFontSize == 1) {
  textYPosition = 27;
 } else if (scrollFontSize == 2) {
  textYPosition = 24;
 } else if (scrollFontSize == 3) {
  textYPosition = 20;
 } else if (scrollFontSize == 4) {
  textYPosition = 16;
 }  else {
  textYPosition = 24;
  byte offSet = 25;
  unsigned long now = millis();
  if (now > isAnimationDue)
    gfx_layer_fg.setTextSize(scrollFontSize);  // size 2 == 16 pixels high
    isAnimationDue = now + scrollSpeed;
    textXPosition -= 1;
    // Checking is the very right of the text off screen to the left
    gfx_layer_fg.getTextBounds(scrollText.c_str(), textXPosition, textYPosition, &xOne, &yOne, &w, &h);
    if (textXPosition + w <= 0) {
      textXPosition = gfx_layer_fg.width() + offSet;
    gfx_layer_fg.setCursor(textXPosition, textYPosition);
    // Clear the area of text to be drawn to
    gfx_layer_fg.drawRect(0, textYPosition - 12, gfx_layer_fg.width(), 42, gfx_layer_fg.color565(0, 0, 0));
    gfx_layer_fg.fillRect(0, textYPosition - 12, gfx_layer_fg.width(), 42, gfx_layer_fg.color565(0, 0, 0));
    uint8_t w = 0;
    for (w = 0; w < strlen(scrollText.c_str()); w++) {
      gfx_layer_fg.print(scrollText.c_str()[w]);
      //Serial.println(textYPosition);
  else {
  if (!scrollTextEnabled && !clockEnabled) { // Both scrollTextEnabled and clockEnabled are false
} /* GIFDraw() */
void * GIFOpenFile(const char *fname, int32_t *pSize)
  Serial.print("Playing gif: ");
  Serial.println(fname);
  f = FILESYSTEM.open(fname);
  if (f)
    *pSize = f.size();
    return (void *)&f;
  return NULL;
 } /* GIFOpenFile() */
void GIFCloseFile(void *pHandle)
  File *f = static_cast<File *>(pHandle);
  if (f != NULL)
     f->close();
 } /* GIFCloseFile() */
 int32_t GIFReadFile(GIFFILE *pFile, uint8_t *pBuf, int32_t iLen)
    int32_t iBytesRead;
    iBytesRead = iLen;
    File *f = static_cast<File *>(pFile->fHandle);
    // Note: If you read a file all the way to the last byte, seek() stops working
    if ((pFile->iSize - pFile->iPos) < iLen)
       iBytesRead = pFile->iSize - pFile->iPos - 1; // <-- ugly work-around
    if (iBytesRead <= 0)
       return 0;
    iBytesRead = (int32_t)f->read(pBuf, iBytesRead);
    pFile->iPos = f->position();
    return iBytesRead;
 } /* GIFReadFile() */
 int32_t GIFSeekFile(GIFFILE *pFile, int32_t iPosition)
  int i = micros();
  f->seek(iPosition);
  pFile->iPos = (int32_t)f->position();
  i = micros() - i;
//  Serial.printf("Seek time = %d us\n", i);
  return pFile->iPos;
 } /* GIFSeekFile() */
 unsigned long start_tick = 0;
 void ShowGIF(char *name)
   start_tick = millis();
   unsigned long lastTimeCheck = millis(); // Timer for getLocalTime
   if (gif.open(name, GIFOpenFile, GIFCloseFile, GIFReadFile, GIFSeekFile, GIFDraw))
     x_offset = (MATRIX_WIDTH - gif.getCanvasWidth())/2;
     if (x_offset < 0) x_offset = 0;
     y_offset = (MATRIX_HEIGHT - gif.getCanvasHeight())/2;
     if (y_offset < 0) y_offset = 0;
     Serial.printf("Successfully opened GIF; Canvas size = %d x %d\n", gif.getCanvasWidth(), gif.getCanvasHeight());
     Serial.flush();
     while (gif.playFrame(true, NULL))
       gfx_layer_bg.dim(150);
       gfx_layer_fg.dim(255);
       gfx_compositor.Blend(gfx_layer_bg, gfx_layer_fg); // Combine the bg and the fg layer and draw it onto the panel.
       if ( (millis() - start_tick) > 50000) { // we'll get bored after about 50 seconds of the same looping gif
         //break; // Will change to the next gif in the list after the set time.
     gif.close();
 } /* ShowGIF() */
void rebootESP(String message) {
  Serial.print("Rebooting ESP32: "); Serial.println(message);
  ESP.restart();
String listFiles(bool ishtml, int page = 1, int pageSize = maxGIFsPerPage) {
  String returnText = "";
  int fileIndex = 0;
  int startIndex = (page - 1) * pageSize;
  int endIndex = startIndex + pageSize;
  File root = FILESYSTEM.open("/");
  File foundfile = root.openNextFile();
  if (ishtml) {
      returnText += "<!DOCTYPE HTML><html lang=\"en\"><head>";
      returnText += "<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">";
      returnText += "<meta charset=\"UTF-8\">";
      returnText += "</head><body>";
      returnText += "<table><tr><th>Name</th><th>Size</th><th>Preview</th><th>Actions</th></tr>";
  while (foundfile) {
      if (fileIndex >= startIndex && fileIndex < endIndex) {
          if (ishtml) {
              returnText += "<tr><td>" + String(foundfile.name()) + "</td>";
              returnText += "<td>" + humanReadableSize(foundfile.size()) + "</td>";
              returnText += "<td><img src=\"/file?name=" + String(foundfile.name()) + "&action=show\" width=\"64\"></td>";
              returnText += "<td>";
              returnText += "<button onclick=\"downloadDeleteButton('" + String(foundfile.name()) + "', 'play')\">Play</button>";
              returnText += "<button onclick=\"downloadDeleteButton('" + String(foundfile.name()) + "', 'download')\">Download</button>";
              returnText += "<button onclick=\"downloadDeleteButton('" + String(foundfile.name()) + "', 'delete')\">Delete</button>";
              returnText += "</td></tr>";
      fileIndex++;
  if (ishtml) {
      returnText += "</table>";
      // Add the Home button
      returnText += "<button onclick=\"window.location.href='/'\">Home</button>";
      // Add the Previous button if applicable
      if (page > 1) {
          returnText += "<button onclick=\"window.location.href='/list?page=" + String(page - 1) + "'\">Previous</button>";
      // Add the Next button if there are more files
      if (fileIndex > endIndex) {
          returnText += "<button onclick=\"window.location.href='/list?page=" + String(page + 1) + "'\">Next</button>";
      // GIF select page
      returnText += "<script>";
      returnText += "function downloadDeleteButton(filename, action) {";
      returnText += "    console.log(`downloadDeleteButton called with filename: ${filename}, action: ${action}`);";
      returnText += "    const url = `/file?name=${filename}&action=${action}`;";
      returnText += "    if (action === 'delete') {";
      returnText += "        fetch(url).then(response => response.text()).then(data => {";
      returnText += "            console.log(data);";
      returnText += "            alert('File deleted successfully!');";
      returnText += "            location.reload();";
      returnText += "        }).catch(error => {";
      returnText += "            console.error('Error deleting file:', error);";
      returnText += "            alert('Failed to delete file.');";
      returnText += "        });";
      returnText += "    } else if (action === 'download') {";
      returnText += "        window.open(url, '_blank');";
      returnText += "    } else if (action === 'play') {";
      returnText += "            alert('Playing file...');";
      returnText += "            console.error('Error playing file:', error);";
      returnText += "            ";
      returnText += "    }";
      returnText += "}";
      returnText += "</script>";
      returnText += "</body></html>";
  root.close();
  return returnText;
String humanReadableSize(const size_t bytes) {
  if (bytes < 1024) return String(bytes) + " B";
  else if (bytes < (1024 * 1024)) return String(bytes / 1024.0) + " KB";
  else if (bytes < (1024 * 1024 * 1024)) return String(bytes / 1024.0 / 1024.0) + " MB";
  else return String(bytes / 1024.0 / 1024.0 / 1024.0) + " GB";
/************************* Arduino Sketch Setup and Loop() *******************************/
  HUB75_I2S_CFG mxconfig(
  PANEL_RES_X,   // module width
  PANEL_RES_Y,   // module height
  PANEL_CHAIN    // Chain length
  mxconfig.gpio.a = A_PIN;
  mxconfig.gpio.b = B_PIN;
  mxconfig.gpio.c = C_PIN;
  mxconfig.gpio.d = D_PIN;
  mxconfig.gpio.e = E_PIN;
  mxconfig.clkphase = false;
  mxconfig.driver = HUB75_I2S_CFG::FM6126A;
  // Display Setup
  dma_display = new MatrixPanel_I2S_DMA(mxconfig);
  dma_display->setRotation(0); // Flip display by 90°, the value can be 0-4
  dma_display->begin();
  dma_display->setBrightness8(sliderValue.toInt()); //0-255
  dma_display->clearScreen();
  Serial.print("Firmware: "); Serial.println(FIRMWARE_VERSION);
  Serial.println("Booting ...");
  Serial.println("Mounting LittleFS ...");
  if (!LittleFS.begin(true)) {
    // if you have not used LittleFS. before on a ESP32, it will show this error.
    // after a reboot LittleFS. will be configured and will happily work.
    Serial.println("ERROR: Cannot mount LittleFS, Rebooting");
    rebootESP("ERROR: Cannot mount LittleFS, Rebooting");
  Serial.println("Starting AnimatedGIFs Sketch");
  Serial.print("Flash Free: "); Serial.println(humanReadableSize((LittleFS.totalBytes() - LittleFS.usedBytes())));
  Serial.print("Flash Used: "); Serial.println(humanReadableSize(LittleFS.usedBytes()));
  Serial.print("Flash Total: "); Serial.println(humanReadableSize(LittleFS.totalBytes()));
  //Serial.println(listFiles(true, 1, maxGIFsPerPage));
  Serial.println("Loading Configuration ...");
  config.ssid = default_ssid;
  config.wifipassword = default_wifipassword;
  config.httpuser = default_httpuser;
  config.httppassword = default_httppassword;
  config.webserverporthttp = default_webserverporthttp;
  Serial.print("\nConnecting to Wifi: ");
  WiFi.begin(config.ssid.c_str(), config.wifipassword.c_str());
  (WiFi.status() != WL_CONNECTED);
  //{ delay(500);
  //Serial.print("."); //Uncomment the 3 lines if you want the ESP32 to wait until the WIFI is connected
 Serial.println("\n\nNetwork Configuration:");
  Serial.println("----------------------");
  Serial.print("         SSID: "); Serial.println(WiFi.SSID());
  Serial.print("  Wifi Status: "); Serial.println(WiFi.status());
  Serial.print("Wifi Strength: "); Serial.print(WiFi.RSSI()); Serial.println(" dBm");
  Serial.print("          MAC: "); Serial.println(WiFi.macAddress());
  Serial.print("           IP: "); Serial.println(WiFi.localIP());
  Serial.print("       Subnet: "); Serial.println(WiFi.subnetMask());
  Serial.print("      Gateway: "); Serial.println(WiFi.gatewayIP());
  Serial.print("        DNS 1: "); Serial.println(WiFi.dnsIP(0));
  Serial.print("        DNS 2: "); Serial.println(WiFi.dnsIP(1));
  Serial.print("        DNS 3: "); Serial.println(WiFi.dnsIP(2));
  // configure web server
  Serial.println("Configuring Webserver ...");
  server = new AsyncWebServer(config.webserverporthttp);
  configureWebServer(); // start web server
  // startup web server
  Serial.println("Starting Webserver ...");
  server->begin();
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer); // get time from NTP server
  dma_display->fillScreen(dma_display->color565(0, 0, 0));
  dma_display->setTextSize(1);
  dma_display->print("ID:"); dma_display->print(FIRMWARE_VERSION);
  dma_display->setCursor(0, 16);
  dma_display->print("IP:"); dma_display->print(WiFi.localIP());
  dma_display->setCursor(0, 38);
  dma_display->print("RSSI:"); dma_display->println(WiFi.RSSI());
  dma_display->setCursor(0, 52);
  dma_display->print("SSID:"); dma_display->println(WiFi.SSID());
  gif.begin(LITTLE_ENDIAN_PIXELS);
 String gifDir = "/"; // play all GIFs in this directory on the SD card
 char filePath[256] = { 0 };
 File root, gifFile;
  if (shouldReboot) {
      rebootESP("Web Admin Initiated Reboot");
  while (1) { // Run forever
      root = FILESYSTEM.open(gifDir); // Open the root directory
      if (root) {
          // Check if a new GIF is requested via the play button
          if (!requestedGifPath.isEmpty()) {
              // Play the requested GIF and set it as the current GIF
              currentGifPath = requestedGifPath; // Update the current GIF path
              requestedGifPath = ""; // Clear the requested path
              // Find and play the requested GIF
              while (gifFile = root.openNextFile()) {
                  if (String(gifFile.path()) == currentGifPath) {
              if (gifFile) {
                  memset(filePath, 0x0, sizeof(filePath));
                  strcpy(filePath, gifFile.path());
                  ShowGIF(filePath);
                  // If looping is enabled, continue looping the requested GIF
                  if (loopGifEnabled) {
                      continue; // Restart the loop for the same GIF
          } else if (!currentGifPath.isEmpty()) {
              // Resume from the last GIF
              gifFile = root.openNextFile(); // Open the first file in the directory
          while (gifFile) {
              if (!gifFile.isDirectory()) { // Play the file if it's not a directory
                  currentGifPath = String(filePath); // Save the current GIF path
                  // Show the GIF
                  ShowGIF(filePath);
                  // If looping is enabled, continue playing the same GIF
              if (!loopGifEnabled) {
                  // If looping is disabled, move to the next GIF
                  gifFile.close();      // Close the current GIF file
                  gifFile = root.openNextFile(); // Open the next file
                  // If no more files, reset to the first file
                  if (!gifFile) {
                      root.close(); // Close the root directory
                      root = FILESYSTEM.open(gifDir); // Reopen the root directory
                      gifFile = root.openNextFile(); // Start from the first file again
                  break; // Exit the loop if looping is disabled
      delay(10); // Pause before restarting
Danke
Da steht doch das Problem. Pass deine platformio.ini entweder manuell an oder verwende den PlatformIO Library Manager:
Danke Hi habe es jetzt Aktualisiert
Aber es will immer noch nicht gehen?
PACKAGES:
Found 42 compatible libraries
Dependency Graph
|-- Adafruit GFX Library @ 1.12.1
|-- AsyncTCP @ 3.4.2
|-- GFX_Lite @ 1.0.0
|-- LittleFS @ 2.0.0
|-- WiFi @ 2.0.0
Building .pio/build/nodemcu-32s/bootloader.bin
Generating partitions .pio/build/nodemcu-32s/partitions.bin
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
Compiling .pio/build/nodemcu-32s/libff9/Wire/Wire.cpp.o
Compiling .pio/build/nodemcu-32s/lib907/SPI/SPI.cpp.o
                                      renameat
                                               renameat
                                          renameat
        atan
            ESP_IDF_VERSION
                               bitClear
                              bitClear
                              bitClear
     return sliderValue;
   Server
                      noTone
                         DST_MET
     request->send(401);
                                         index
                           MAX_INPUT
Compiling .pio/build/nodemcu-32s/lib2da/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
Compiling .pio/build/nodemcu-32s/lib2da/Adafruit BusIO/Adafruit_GenericDevice.cpp.o
Compiling .pio/build/nodemcu-32s/lib2da/Adafruit BusIO/Adafruit_I2CDevice.cpp.o
                                          lutimes
                       lutimes
         close
         close
         close
Compiling .pio/build/nodemcu-32s/lib2da/Adafruit BusIO/Adafruit_SPIDevice.cpp.o
         spiSSEnable
       spiSSEnable
       clock_nanosleep
           clock_nanosleep
              bitClear
                                      renameat
                                               renameat
                                          renameat
        atan
Archiving .pio/build/nodemcu-32s/libff9/libWire.a
Indexing .pio/build/nodemcu-32s/libff9/libWire.a
src/main.cpp: In function 'String listFiles(bool, int, int)':
src/main.cpp:401:38: error: 'humanReadableSize' was not declared in this scope
src/main.cpp: In function 'void setup()':
src/main.cpp:550:3: error: 'configureWebServer' was not declared in this scope
src/main.cpp:550:3: note: suggested alternative: 'AsyncWebServer'
   AsyncWebServer
========================================================================== [FAILED] Took 4.21 seconds ==========================================================================
Der Sourcecode ist ungünstig strukturiert und in den beiden (ehemaligen) ino Dateien so aufgeteilt, dass Variablen/Objekte erst nach dem Gebrauch definiert werden.
Weil die PlatformIO Umgebung den Quellcode, im Gegensatz zur Arduino IDE, nicht automatisch zurecht sortiert, wird das zum Problem. Da muss man das gleich richtig machen.
Ich habe mal auf die schnelle (sehr unschön) etwas zurechtgebastelt. So lässt sich der Code wenigstens kompilieren...
Das PlatformIO Projekt ist diesem Posting angehangen. Entpacke es in Deinem Projektordner lade es in VSC und dann ... viel Glück...
HUB75-Pixel-Art-Display.zip (18,4 KB)
Vielen Danke :blue_heart:
Also is der Code Schlecht gebaut?
Komisch wenn ich die alter Version nutze geht mein Display nutze ich 4.5 Lad Bild hoch bleibt es Dunkel.... Aber das Display geht wenn ich den ESP Einsteck kommen kurz die Info.... IP VERSION etc...
Download der Alten Version
HUB75-Pixel-Art-Display-dev.zip (689,8 KB)
So ich hab es jetzt nochmal mit Arduino versucht Das Display geht wie man im Video 1A sieht.... auch Hochladen nur das Anzeigen will nicht mehr gehen.....
Der macht sich das mit sein Antwort auch einfach hab das gemach kein Verbesserung
Sagt aber auch es wär ja nicht sein Firmenware die Probleme macht jaja komisch bei 2.2 ging es bei 4.5 nicht mehr.... bei wemm liegt jetzt der Fehler...... das geil er Schließ danch direkt den Beitrag....
