Can I use the sdfat library to play audio through SD Card?
Because when I use the sdfat library with TMRpcm library at the same form, it causes many problems
Not quite sure what you mean by 'play audio through SD Card' ?
Do you mean that you have a file on the SD, and you somehow want an Arduino to turn it into music ?
Thank you for caring, yes, this is what I mean
