Play multiple piezos simultaneously
Hi there:
For my project, I’m trying to have an infrared sensor trigger the sounding of 5 piezos. The piezos would be playing at the same frequency (4000 Hz), and at the same time.
I’ve succeeded in having the sensor trigger 1 piezo, but for some reason my code for 5 piezos does not work.
I’ve attached a diagram of the setup below, as well as the code:
IRSong is my working code for 1 piezo
IRSong_5piezos is my attempted code for 5 piezos
IR Song sketch_bb.pdf is a diagram of my setup
Thanks so much guys!
IR Song sketch_bb.pdf (599 KB)
IRSong.ino (1.1 KB)
IRSong_5piezos.ino (1.19 KB)
rkduino:
In that case, why not just put all the piezos in parallel and drive them off the same signal?
From the tone() webpage:
Only one tone can be generated at a time. If a tone is already playing on a different pin, the call to tone() will have no effect. If the tone is playing on the same pin, the call will set its frequency.
https://www.arduino.cc/en/Reference/Tone
My suspicion is that this code
    tone(9, 4000, 100);
    tone(10, 2000, 100);
    tone(11, 2000, 100);
    tone(12, 1000, 100);
    tone(13, 500, 100);
may have violated the limitation above.
I’d try putting a delay of 105ms after each call to tone()
tone(9, 4000, 100);
delay(105);
delay(105);
delay(105);
delay(105);
tone(13, 500, 100);
delay(105);
rkduino:
Your code won't do that. You've got a mix of frequencies in the code I quoted above. And as I pointed out previously, issuing a succession of calls to tone(), without any delays in between, may cause problems.
