Play sounds and light up LED with IR remote, how do I loop things?
It would be simpler, IMO, to put all the IR codes that correspond to tracks in an array like this:
// ir codes for tracks
unsigned int trackCodes[] = {41565, 25245, 57885};
// record # of tracks
int numTrackCodes = sizeof(trackCodes) / sizeof(trackCodes[0]);
Then your switch statement could be turned upside down to handle the "special" keys first and if one of those has not been clicked look at the codes for each track. If one of those keys has been clicked use the IR code index in the array to play the proper track.
  if (receiver.decode(&output)) {
    unsigned int value = output.value;
    switch (value) {
      //turn LED on or off
      case holo_key:
        if (led[1] == 1) {
          digitalWrite(holo_pin, LOW);
          led[1] = 0;
          digitalWrite(holo_pin, HIGH);
          led[1] = 1;
        break;
      //play random sound
      case audio_random:
        myPlayer.playFileAndWait(random(1, 9), 10);
        break;
      //play random sound in loop with delay
      case audio_random_loop:
        delay (random(1200, 3000));
        break;
      default:
        int idx;
        // find index based on ir code
        for (idx = 0; idx < numTrackCodes; idx++) if ( trackCodes[idx] == value ) break;
        //play specific sound
        if ( idx < numTrackCodes ) myPlayer.playFileAndWait(idx+1, 10);
        break;
    Serial.println(value);
    receiver.resume();
