Hello fellas!
I have put some wav file in the qspi partition (around 13Mb).
It works fine if I don't use the loop to write the buff to the dac like this: dac0.write(buf);
But once I put it in the loop it crashes and I have no idea why.
The code is the same of the official arduino web site here the link https://docs.arduino.cc/tutorials/giga-r1-wifi/giga-audio/
I just removed the access to USB and add this in the setup, to use the qspi storage:
mbed::BlockDevice* raw_qspi = mbed::BlockDevice::get_default_instance();
mbed::FATFileSystem ota("ota");
mbed::MBRBlockDevice ota_data(raw_qspi, 2);
ota.mount(&ota_data);
It works fine I can read and write files or list them, indeed the next line is :
file = fopen("/ota/ready.wav", "rb");
if (file == nullptr) {
Serial.print("Error opening audio file: ");
Serial.println(strerror(errno));
return;
Then there is the code like the example in the link, but if I put this at the end of the setup I can hear the wav playing nice:
while (!feof(file) && dac0.available()) {
uint16_t sample_data[256] = { 0 };
fread(sample_data, sample_size, 256, file);
SampleBuffer buf = dac0.dequeue();
for (size_t i = 0; i < buf.size(); i++) {
uint16_t const dac_val = ((static_cast<unsigned int>(sample_data[i]) + 32768) >> 4) & 0x0fff;
buf[i] = dac_val;
dac0.write(buf);
But if I remove the while loop to use the main loop() like this, it does not work:
if (!feof(file) && dac0.available()) {
/* Read data from file. */
Serial.println("Stemp1");
/* Get a free buffer for writing. */
Serial.println("Step2");
/* Write data to buffer. */
/* Scale down to 12 bit. */
buf[i] = dac_val;
Serial.println("Step3");
/* Write the buffer to DAC. */
dac0.write(buf);
In the log it seems it crashes at the second time it goes inside the if. I got this in the log:
Step1
Step2
Step3
And then Crash
