play with buttons through mcp23s17
need help of you clever people :slight_smile:
I’m trying to make an easy processing of many buttons that will eventually get functions. but my code gets either no reaksion or a lot of random letters.
think it has something to do with my array
#include <SPI.h>              // We use this library, so it must be called here.
#include <MCP23S17.h>         // Here is the new class to make using the MCP23S17 easy.
MCP inputchip(0);             // Instantiate an object called "inputchip" on an MCP23S17 device at address 1
MCP outputchip(1);            // Instantiate an object called "outputchip" on an MCP23S17 device at address 2
int Kp[80];
int KpG[80];
  Serial.begin(9600);            // Use the serial port
  inputchip.pinMode(0xFFFF);     // Use word-write mode to set all of the pins on inputchip to be inputs
  inputchip.pullupMode(0xFFFF);  // Use word-write mode to Turn on the internal pull-up resistors.
  inputchip.inputInvert(0xFFFF); // Use word-write mode to invert the inputs so that logic 0 is read as HIGH
  outputchip.pinMode(0x0000);    // Use word-write mode to Set all of the pins on outputchip to be outputs
          Serial.println("loop");
  int value;                        // declare an integer to hold the value temporarily.
  value = inputchip.digitalRead();  // reads the first input chip in word mode
   if (value > 0){
   KeyToInt(value, 1);               // convert readings and store in array
      Serial.println(value);
 // treats array
  for (int i = 0; i < sizeof(Kp); i++){
   if (Kp[i] > 0){
     // Press started or continue
     KpG[i] = KpG[i]++;
   else if (Kp[i] == 0 && KpG[i] > 0){
     // Press finished
     Serial.println("Press finished nr.");
     Serial.println(i);
     Serial.println("number of loop");
     Serial.println(KpG[i]);
     KpG[i] = 0;
 // reset kp[] to next loop
 char Kp[96];
void KeyToInt(int y, int z){
    long x=32768;                            // largest word number 16 pin
  for (int count=16; count > 0; count--){    // loop through 16 pin
    if ((y - x) >= 0){
      y = y - x;
      // insert 1 in the array by key
      int cpin = (16 * z) + count;           // chip number * 16 buttons per chip + button number
      Kp[cpin] = 1;
  x = x / 2;
hope you can help me
chosen another solution
