Hi!
I've been trying to figure out how to make my Arduino UNO play a melody, but I want it to be programmable so that I can put in different notes for other melodies. There are a couple of variables that I would like to include in my code and these are tone length, tempo and of course the tone. Also, the button is there to start the melody, and I intend for the led to be blinking when the melody can be started by pressing the button, but I think I will be able to code these things later. Here is my code so far:
//Own Project 000 Melody player v.1
int button = 4;
int speaker = 5;
int led = 6;
int buttonState = 0;
// int tempo = 1;
int toneFrequency = 0;
int toneLength = 0;
int waitTime = 1000000 / (toneFrequency * 2);
int startMicros;
int currentMicros;
int period = 1000000;
int H () {
toneLength = 1;
int I () {
toneLength = 2;
int J () {
toneLength = 3;
int K () {
toneLength = 4;
int C () {
toneFrequency = 261;
int D () {
toneFrequency = 294;
int E () {
toneFrequency = 329;
int F () {
toneFrequency = 349;
int G () {
toneFrequency = 392;
int A () {
toneFrequency = 440;
int B () {
toneFrequency = 493;
int C2 () {
toneFrequency = 523;
int playNote () {
currentMicros = micros();
if ((currentMicros - startMicros) >= (period * toneLength)) {
digitalWrite(speaker, HIGH);
delayMicroseconds(waitTime);
digitalWrite(speaker, LOW);
startMicros = currentMicros;
pinMode(speaker, OUTPUT);
pinMode(led, OUTPUT);
pinMode(button, INPUT);
startMicros = micros();
H ();
C ();
playNote ();
I ();
F ();
playNote ();
I ();
F ();
playNote ();
H ();
G ();
playNote ();
H ();
A ();
playNote ();
H ();
B ();
playNote ();
H ();
G ();
playNote ();
I ();
A ();
playNote ();
H ();
G ();
playNote ();
H ();
A ();
playNote ();
As you can see I haven't really figured out a way to work the tempo variable into my code (and thus it is behind // at the start of the code), but I did want to try it out to see if it would work for as far as I've gotten.
When I tried to compile the code, however, I got this error message:
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Uno"
In file included from /Users/Ruben/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino/Arduino.h:231:0,
from sketch/Melody_player_v.1.ino.cpp:1:
/Users/Ruben/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino/WString.h:38:28: error: expected unqualified-id before 'reinterpret_cast'
#define F(string_literal) (reinterpret_cast<const __FlashStringHelper *>(PSTR(string_literal)))
/Users/Ruben/Documents/Persoonlijke documenten/Arduino/Own Projects/Melody_player_v.1/Melody_player_v.1.ino:39:5: note: in expansion of macro 'F'
int F () {
/Users/Ruben/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino/WString.h:38:28: error: expected ')' before 'reinterpret_cast'
int F () {
In file included from /Users/Ruben/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino/Arduino.h:28:0,
/Users/Ruben/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino/WString.h:38:74: error: expected unqualified-id before ')' token
int F () {
/Users/Ruben/Documents/Persoonlijke documenten/Arduino/Own Projects/Melody_player_v.1/Melody_player_v.1.ino: In function 'void loop()':
/Users/Ruben/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino/WString.h:38:74: error: expected primary-expression before ')' token
/Users/Ruben/Documents/Persoonlijke documenten/Arduino/Own Projects/Melody_player_v.1/Melody_player_v.1.ino:80:3: note: in expansion of macro 'F'
F ();
/Users/Ruben/Documents/Persoonlijke documenten/Arduino/Own Projects/Melody_player_v.1/Melody_player_v.1.ino:83:3: note: in expansion of macro 'F'
F ();
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
So basically I have two questions:
- What is wrong with the code for it to give this error message?
- What would be the best way to implement the tempo function into my code?
I would appreciate any help!
Thanks!
P.S. I am aware that there are better and more compact ways of playing a melody using an Arduino, but I wanted to challenge myself and come up with a way to do this with the very limited knowledge I have of Arduino coding at the moment.
