Playing a WAV file Popping and Humming.
Hello some odd reason there is a Humming and popping when playing a Wav file from Sd card module. I followed this guy video Here on how to make the Audio play though the Sd card on the arduino and it works but i get Popping and humming from the speakers and not sure why. can someone please help me out the sketch is below.
#include <TMRpcm.h>
#include <SPI.h>
#include <SD.h>
char mychar;
const int CS_PIN = 10;
TMRpcm tmrpcm;
  tmrpcm.speakerPin = 9;
  tmrpcm.setVolume(4);
  Serial.println("Initializing Card");
  pinMode(CS_PIN, OUTPUT);
  if(!SD.begin(CS_PIN)) {
    Serial.println("Card Failure");
    return;
  Serial.println("Card Ready");
  tmrpcm.play("e.wav");
but when the music stop the humming is still there but the popping is gone.
I found out the problem I'm having is that the dac is not enough But I'm not sure if that is correct maybe this is a programming problem not a audio problem? maybe need a better Dac?
Hello is there a way to move this topic to programming please?
Moved.
Thank you.
