Playing mp3 with 2 fingers!
Hey everyone,
My project is having 2 wired gloves : thumbs are connected to ground and other fingers connected to pins 2, 3, 4, 5, A2, A3, A4, A5.
When a finger touchs thumb, it plays an mp3.
I use arduino uno and DFPlayer Mini.
My code is working when the touch between fingers is short.
When 2 fingers stay in contact a few seconds the song is played another time when fingers separate.
As the state of the pin changes from HIGH to LOW randomly.
Thanks in advance for your help :slight_smile: :wink:
Here is my code :
SoftwareSerial mySerial(10, 11);
DFRobotDFPlayerMini myDFPlayer;
SD CARD : Folder mp3
01 / 8 samples for 8 fingers (thumbs = ground)
define ACTIVATED LOW
const int button[8] = {2, 3, 4, 5, A2, A3, A4, A5};
bool state[8] = {0, 0, 0, 0, 0, 0, 0, 0};
bool lastState[8] = {0, 0, 0, 0, 0, 0, 0, 0};
void setup ()
for ( int i = 0 ; i < 8 ; ++i)
pinMode(button[i], INPUT_PULLUP);
digitalWrite(button[i], HIGH);
mySerial.begin (9600);
Serial.write("Initializing DFPlayer\n");
if (!myDFPlayer.begin(mySerial))
{ //Use softwareSerial to communicate with mp3.
Serial.write("Unable to begin\n");
while (true);
Serial.write("DFPlayer Ready\n");
myDFPlayer.volume(25); //Set volume value (0~30).
//----Set different EQ----
myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);
FONCTIONS
void playSong(int folder, int track)
delay(100);
myDFPlayer.playFolder(folder, track);
void loop ()
for (int i = 0 ; i < 8 ; ++i)
state[i] = digitalRead(button[i]);
if (state[i] != lastState[i])
if (state[i] == ACTIVATED)
playSong(1, i);
lastState[i] = state[i];
I think you simply forgot to debounce the switch inputs?
Hi MarkT,
Thank you so much !
You have the solution.
Now with the delay() function at the right place it works !
Thanks again
my code :
//INFINITE LOOP
void loop ()
delay(100); //debounce
    myDFPlayer.playFolder(1, i);
