Playing song using I2c with 2 UNO boards
I am fairly new to the world of Arduino programming and need help with some code. The intended purpose of the code is to designate one board to be a “master” and the other as a “slave”. I am trying to get the master to send a simple “1” integer to the slave, which then runs the music playing program. The master program runs fine but I am having trouble with the slave program. The “void playTone ()” function is meant to be run outside of the void loop and I cannot get it to call it and run the function. The code should work but any help would be appreciated. Thanks for the help! I have attached the slave code below
#include <Wire.h>
#define c 3830 // 261 Hz
#define d 3400 // 294 Hz
#define e 3038 // 329 Hz
#define f 2864 // 349 Hz
#define g 2550 // 392 Hz
#define a 2272 // 440 Hz
#define b 2028 // 493 Hz
#define C 1912 // 523 Hz
#define R 0
int speakerOut = 9;
int DEBUG = 1;
int x = 1;
int melody = { C, b, g, C, b, e, R, C, c, g, a, C };
int beats = { 16, 16, 16, 8, 8, 16, 32, 16, 16, 16, 8, 8 };
int MAX_COUNT = sizeof(melody) / 2; // Melody length, for looping.
// Set overall tempo
long tempo = 10000;
// Set length of pause between notes
int pause = 1000;
// Loop variable to increase Rest length
int rest_count = 100; //<-BLETCHEROUS HACK; See NOTES
// Initialize core variables
int tone_ = 0;
int beat = 0;
long duration = 0;
Wire.begin(9);
// Attach a function to trigger when something is received.
Wire.onReceive(receiveEvent);
void receiveEvent(int bytes) {
x = Wire.read(); // read one character from the I2C
if (x == ‘1’){
playTone ();
// Set up a counter to pull from melody and beats
for (int i=0; i<MAX_COUNT; i++) {
tone_ = melody*;*
_ beat = beats*;_
_ duration = beat * tempo; // Set up timing_
_
playTone();_
_
// A pause between notes…_
_
delayMicroseconds(pause);_
_
if (DEBUG) { // If debugging, report loop, tone, beat, and duration*_
* Serial.print(i);*
* Serial.print(":");*
* Serial.print(beat);*
* Serial.print(" "); *
* Serial.print(tone_);
_
Serial.print(" ");_
_
Serial.println(duration);_
_
}_
_
}_
_
}_
void playTone() {
long elapsed_time = 0;
if (tone_ > 0) { // if this isn’t a Rest beat, while the tone has*
* // played less long than ‘duration’, pulse speaker HIGH and LOW*
* while (elapsed_time < duration) {
_
digitalWrite(speakerOut,HIGH);_
delayMicroseconds(tone_ / 2);
_
// DOWN*_
* digitalWrite(speakerOut, LOW);*
* delayMicroseconds(tone_ / 2);
_
// Keep track of how long we pulsed*_
* elapsed_time += (tone_);
_
}_
_
}_
_
else { // Rest beat; loop times delay*_
* for (int j = 0; j < rest_count; j++) { // See NOTE on rest_count*
* delayMicroseconds(duration); *
The receiveEvent() should be very short and fast. It is (part of) an interrupt handler.
It is possible to send a commend from the receiveEvent() to the loop() with a variable. If only a 8-bit variable is used, there is no need to turn off interrupts when it is read or written in the loop. But it must be made 'volatile'.
volatile char command = 0;              // set de default : no command
  command = Wire.read();    // read one character from the I2C
  if( command != 0)        // received a command ?
    playTone...
    command = 0;            // clear the command
