Playing sound tracks on PC by the data from arduino
Recently, I am doing a project which is using the RFID-RC522 and Arduino to obtain the UID of a card. Then, I wish to use the UID to do a matching between different soundtracks on PC so that it will respond me with a specific track.
From this stage, I have already found the way to obtain UID, but I have found that there were no method for me to play music on PC if I am using Arduino IDE.
Here is the code I altered from MFRC522 library's Dumpinfo,
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         5         // Configurable, see typical pin layout above
#define SS_PIN          10         // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
	Serial.begin(9600);		// Initialize serial communications with the PC
	while (!Serial);		// Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
	SPI.begin();			// Init SPI bus
	mfrc522.PCD_Init();		// Init MFRC522
	mfrc522.PCD_DumpVersionToSerial();	// Show details of PCD - MFRC522 Card Reader details
	Serial.println(F("Scan PICC to see UID, SAK, type, and data blocks..."));
        // Look for new cards
        if ( ! mfrc522.PICC_IsNewCardPresent()) {
                return;
        // Select one of the cards
        if ( ! mfrc522.PICC_ReadCardSerial()) {
                return;
        // Dump debug info about the card. PICC_HaltA() is automatically called.
        //mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
        //Serial.println(&(mfrc522.uid));
        Serial.print(F("Card UID:"));
          for (byte i = 0; i < mfrc522.uid.size; i++) {
          Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
          Serial.print(mfrc522.uid.uidByte[i], HEX);
       delay(5000);
You need to have a program running on the PC which can receive a message from the Arduino and then perform the task on the PC.
This Python - Arduino demo may help get you started.
...R
