playing sound with the arduino Leonardo
Hi all,
I want to play a small sound file with the arduino and was wondering if I can put the sound file on the atmega chip so I don't have to buy a a Sd card shield,
Thanks in advance,
Lukas
This is almost the same question : How to run pulse-code modulation(PCM) on the Arduino Leonardo? - Microcontrollers - Arduino Forum
Data can be set into the flash of the atmega chip, next to the progam code.
It is called 'PROGMEM' : PROGMEM - Arduino Reference
Which library do you want to use the play the sound data ?
Idk is there a library the will play .wav or .mp3 or something like that if I have to I can use a raspi.
The other topic shows a way to translate a file to code for in the Arduino and to play it. It is not working yet, but I have also not tried it.
The Mozzi library is also able to use samples.
But it will take everything from a normal Arduino board to play sampled sound. You can not just play a file.
Ok thanks a ton ill just use my raspberry pi for this
Thanks,
Lukas
