Hi All, I was just wondering how I would set the arduino up so it could play a tune when a push button is pressed, I have tested the toneMelody sketch and it works perfectly, How would I edit the coding to insert a pushbutton read to start the tune.
Kind regards, Steve
if (digitalRead (pinX)==LOW){ // play tone }
in void setup:
pinMode (pinX, INPUT_PULLUP); // pin with internal pullup, wire switch to close to gnd when pressed
ok, Thanks for the help. Thankyou muchly.
Steve
