Playing WAV audio from SD-card with Arduino DUE
Can the DUE handle to play a WAV file more than once? The sketch below works sometimes. After a while the files play hampered. Same problem when I play the same file (instead of 4 here). Who can help me out? My artwork has a deadline and I’m losing days without progress…
I use a DUE with Adafruit SD-card reader connected to the SPI and 2.5W amp on the DAC0.
  DUE - SD card WAV player BUTTON
 The circuit: use 6-pin SPI connector
  Uno 10  CS   SS     Due  10
      11  DI   MOSI        ICSP-4
      12  DO   MISO        ICSP-1
      13  CLK  SCK         ICSP-3
#include <SPI.h>
#include <SD.h>
#include <Audio.h>
File myFile;
// const int SS = 10; (Chipselect const SS declared in SD.h)
const int btnPin = A2;
const int ledPin = A3;
int trkSel = 1;
int buttonState = LOW;
  pinMode(btnPin, INPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(SS, OUTPUT);
  digitalWrite(ledPin, LOW);
  Serial.print("\nInitializing SD card...");
  if (!SD.begin(SS)) {
    Serial.println(" Failed!");
    return;
  Serial.println(" OK.");
  // 44100kHz stereo => 88200 sample rate, 100 mSec of prebuffering:
  Audio.begin(88200, 100);
  // WAV sample file ID scheme = PRF-BNK-TRK.wav
  int sPRF = 1;  // Performance#
  int sBNK = 1;  // Sample bank
  int sTRK = 1;  // Sample track
  int OK;        // return value (0 is ok)
  buttonState = digitalRead(btnPin);
  if (buttonState == HIGH)
    digitalWrite(ledPin, HIGH);
    OK = macePod(sPRF, sBNK, trkSel, 1500, 0, 512);
    Serial.print("\n*** macePod "); Serial.println(OK);
    trkSel++;
    if (trkSel > 4 ) {
      trkSel = 1;
int macePod(int PRF, int BNK, int TRK, int duration, int pitch, int vol) {
  char sampleFile[20];
  const int S = 1024; // Number of samples to read in block
  short buffer[S] = {};
  int volume = vol;
  sprintf(sampleFile, "%d-%d-%d.wav", PRF, BNK, TRK);
  Serial.print("[Sample "); Serial.print(TRK); Serial.print("] ");
  // open wave file from sdcard
  myFile = SD.open(sampleFile);
  if (!myFile) {
    return 1;
  int count = 0;
  while (count <= duration / 10) {
    // read from the file into buffer
    myFile.read(buffer, sizeof(buffer));
    // Prepare samples
    Audio.prepare(buffer, S, volume);
    // Feed samples to audio
    Audio.write(buffer, S);
    count++;
  myFile.close();
  return 0;
What the heck does this mean?
By convention, all capital letter names are reserved for constants. Function arguments are, by definition, not constants.
Your code is missing comments where they would be useful, such as
  int count = 0;
but has them where they state the obvious, like:
There seems to be NO relationship between count and duration.
