Playing with LCD's
Hi all, i just ordered my first LCD to start playing around with, on the suppliers site it says "Utilizes the common ST7066/HD44780 parallel interface" and it goes on to say that "You will need ~11 general I/O pins to interface to this LCD screen."! would it be possible to use a shift register such as the 74HC595 to reduce the number of pins needed? i read somewhere that it was described as a serial to parallel converter.
At the moment i don't fully under stand how the 74HC595 works. i just did a tutorial where you use a shiftout function to essentially make 8 LED's count to 256 in binary. Which was cool in a geeky way :slight_smile:
So can you use the 75HC595 to reduce the number of pins needed for the LCD screen? Anyone done something like that before?
here is a link to the 75HC595 data sheet http://www.sparkfun.com/datasheets/IC/SN74HC595.pdf and the data sheet for the LCD screen i just brought http://www.sparkfun.com/datasheets/LCD/ADM1602K-NSW-FBS-3.3v.pdf
Before i try to use it with the shift register if i can i plan to learn the basics by doing this tutorial Arduino Tutorial - connecting a parallel LCD
So what do you all think :slight_smile:
Yes, you can save I/O pins usig a shift register. Do a search from the arduino.cc homepage, and you'll find examples (and even a library for use with the HC595, iirc).
Note that the spec sheet you referenced is for a display designed to run off 3.3V. Unless you're using a 3.3V Arduino (like the Lilypad or some of the Pro Mini versions), you may damage the display by hooking it up to a 5V system. The logic inputs are probably (but not certainly) 5V-tolerant, but the LED backlight probably has its current-limiting resistor set for 3.3V. There's a decent chance that it won't last long at 5V.
The standard HD44780 type LCDs will work fine with 6 digital connections rather than 11. Use the 4 upper data pins and tie RW to ground.
Oh :frowning: I didn't see that. I guess I have learnt my lesson. Any tips on how i can safely get it down to 3.3V? I am working my way through some some info i found on google but their seems to be a few different methods.
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=65 this looks like it could be the way to go. but it is a little confusing :slight_smile: I am new to all of this.
So any tips?
If it is just logic signals then a simple potential divider will do the trick.
However if it is to power something you need a voltage regulator.
Well i got in contact with the online store and asked them to change it to the 5V equivalent. Hopefully it hasn't been shipped yet and they can change it. either way i will be a good learning experience.
Would i have to use a voltage regulator for each pin? So 6 for the digital pins, and one for the 5V power? so i would need 7 all up?
I fond this one, is that what i would need? http://www.littlebirdelectronics.com/products/Voltage-Regulator-%252d-3.3V.html
No you only need a voltage regulator to supply the power. The signal pins can be cut down with a potential divider.
Hmmm ok, I have been looking around, doing some googleing but i am a bit lost. How do i know/work out what one i would need? do you know where i could find some info about them... do you know of some good documentation...
I posted two links?
Look at the schematic here:-
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1206874649/8
I posted two links?
Sorry, it's getting late and i am getting tired :slight_smile:
Ok, so by looking at that schematic I did the maths it should put out 3.24V { 3.24=5x3300/(1800+3300) } So using that method for the 6 pins and using the voltage regulator for the power supply.
hmmmm nice and easy really :slight_smile:
