Plc control board and arduino for solenoids and motors
Hi everyone,
I am trying to solve a simple question (I think). I found this circuit board and I was wondering if I could use it as a power circuit :
My idea is to connect the arduino outputs to the gates of the mosfets, letting the current flow through some solenoids, motors, fluorescent tube.
The thing is I am not familiar with PLC circuits at all and would need some advice. It seems a bit more tricky than I expected. Also I would need to choose between PNP and NPN input. I beed to be able to control this via PWM also...
I hope someone will be able to help.
Cheers.
There's a mistake in the specifications but I don't think it's fatal. It says the "output contacts" are 5A 250V but that would only be true if you were using this board to drive a 5A 250V relay.
I don't see where you choose PNP or NPN input. It probably doesn't matter. A 5V Arduino will probably drive this just fine with either option.
The 5KHz "switching frequency" indicates that it will work with PWM just fine.
Thanks MorganS and sorry for the late reply!
I will order one board and write a review on this thread for documentation.
