Hello I was wondering if it was at all possible to put TON blocks in the parallels rungs. I've used PLC's before and I'm certain this a function I can do. if anyone is able to. what version of the software are you running?
I don't see why not. Its been a while since I worked with PLC's but it looks fine to me.
Hey @noweare, that's what I thought but when I tried to drag and drop the TON Timer over next to the EQ_4_BOOL bit, it just won't appear with in the Parallel rung.
no, you can't put TON block in parallel rung !
One of the weird PLC IDE limitation !!
Thank you for confirming Kalain
There are a LOT of weird PLC IDE limitations... Hopeful of a big update soon
