I have 2 PLC mamba modules mounted on 2 Arduino UNO boards. Both the boards run interrupt driven example code provided by Linksprite GitHub - linksprite/mamba: Mamba, Arduino Powerline Communication Shield .
Now the usecase and problems I faced are as follows:
I am using a serial terminal software (Docklite) to send and receive data between the 2 PLC modules. Baud Rate:9600 - 8 data bits-No parity-1 stop bit
If I turn on the real time feed from keyboard, it works fine. Everything I type gets transmitted flawlessly to the end device.
However if I try to transmit a string at a go, it starts skipping bytes. If I give "abcde" as input, it is received as "abce", 'd' goes missing.
Please advise. Thanks for the help. I really couldn't find any resources on the boards.
-Gaurav
