The links you provided are for an embedded ARM system, they're unable to do networking over power lines. Powerline Networking is probably what you're talking about, like www.homeplug.org. You can probably just use an ethernet shield and an off the shelf ethernet to powerline adapter like these http://www.dlink.com/products/?pid=533
An ethernet shield + powerline adaptater is a good option. However, it's extremely expensive, and it's 2 separate pieces of electronics
I'd like to know how to create my own plug like the dlink plug, with an arduino
I'd like in fact this arduino to be able to send small amount of data by powerline
This plus doesn't need to provide an external RJ45 plug, because arduino may be too slow to connect a PC to powerline
Any idea to have a low cost plug that can do powerline networking ?
I'd be interested in this also.
My idea is to use the arduino as an electricity meter for an appliance such as a fridge which would report its electricity usage back to another arduino which could then have an ethernet link to a router allowing the uploading of usage data to a database. A third arduino could plug into the mains and display the current usage on an LCD.
Does anyone know if the techology used by the homeplug people is hackable, i.e. any scope for DIY work. I think a simpler protocol than ethernet would do the job just fine. Any suggestions ?
Best regards / Colm
