PLC pulse signal wireless transiever
Hello everybody,
I'm trying to implement a plc pulse wireless transciever with a frequency of 20khz signal.
Is there applicable way to transmit this signal wirelessly and recieve it over a 250 meters distance.
250 meters is a long distance, but with line of sight these might work.
Thanks for your reply , i have read the data sheet of your mentioned link and found the transfer rate is 4kbps which is lower than the required data rate , i have tried to implement it with nrf24L01 but i could not succeed with as i used a badly manufactured chineese nrf so i will buy another two modules and i will try again.
i appreciate If you have a recommended video or any data that helps
