I installed the correct libraries and now I get more errors.
Arduino: 1.8.5 (Windows 7), Board: "Generic ESP8266 Module, 80 MHz, ck, 26 MHz, 40MHz, QIO, 512K (no SPIFFS), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Build options changed, rebuilding all
C:\Users\KKozlows\AppData\Local\Temp\Temp1_plduino (8).zip\plduino\plduino.ino: In function 'void setup()':
plduino:166: error: 'Serial2' was not declared in this scope
Serial2.begin(FLASH_ESP_BAUD);
plduino:174: error: request for member 'html' in 'index', which is of non-class type 'char*(const char*, int)'
File f = SD.open(index.html, FILE_READ);
plduino:176: error: no matching function for call to 'ESP8266WebServer::on(const char [2], int)'
server.on("w", f.read());
C:\Users\KKozlows\AppData\Local\Temp\Temp1_plduino (8).zip\plduino\plduino.ino:176:30: note: candidates are:
In file included from C:\Users\KKozlows\AppData\Local\Temp\Temp1_plduino (8).zip\plduino\plduino.ino:3:0:
C:\Users\KKozlows\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WebServer\src/ESP8266WebServer.h:87:8: note: void ESP8266WebServer::on(const String&, ESP8266WebServer::THandlerFunction)
void on(const String &uri, THandlerFunction handler);
C:\Users\KKozlows\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WebServer\src/ESP8266WebServer.h:87:8: note: no known conversion for argument 2 from 'int' to 'ESP8266WebServer::THandlerFunction {aka std::function<void()>}'
C:\Users\KKozlows\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WebServer\src/ESP8266WebServer.h:88:8: note: void ESP8266WebServer::on(const String&, HTTPMethod, ESP8266WebServer::THandlerFunction)
void on(const String &uri, HTTPMethod method, THandlerFunction fn);
C:\Users\KKozlows\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WebServer\src/ESP8266WebServer.h:88:8: note: candidate expects 3 arguments, 2 provided
C:\Users\KKozlows\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WebServer\src/ESP8266WebServer.h:89:8: note: void ESP8266WebServer::on(const String&, HTTPMethod, ESP8266WebServer::THandlerFunction, ESP8266WebServer::THandlerFunction)
void on(const String &uri, HTTPMethod method, THandlerFunction fn, THandlerFunction ufn);
C:\Users\KKozlows\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WebServer\src/ESP8266WebServer.h:89:8: note: candidate expects 4 arguments, 2 provided
plduino:195: error: no match for call to '(ESP8266WebServer) (char&)'
int a = server(label);
plduino:197: error: converting to 'const String' from initializer list would use explicit constructor 'String::String(int, unsigned char)'
server.on(a, LEDdim);
C:\Users\KKozlows\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WebServer\src/ESP8266WebServer.h:87:8: error: initializing argument 1 of 'void ESP8266WebServer::on(const String&, ESP8266WebServer::THandlerFunction)'
Multiple libraries were found for "SD.h"
Used: C:\Users\KKozlows\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\SD
Not used: C:\Users\KKozlows\Documents\Arduino\libraries\SD
Not used: C:\Program Files (x86)\Arduino\libraries\SD
exit status 1
C:\Users\KKozlows\Documents\Arduino\sketch_jul03a\sketch_jul03a.ino: In function 'void setup()':
sketch_jul03a:175: error: request for member 'html' in 'index', which is of non-class type 'char*(const char*, int)'
sketch_jul03a:177: error: no matching function for call to 'ESP8266WebServer::on(const char [2], int)'
C:\Users\KKozlows\Documents\Arduino\sketch_jul03a\sketch_jul03a.ino:177:30: note: candidates are:
In file included from C:\Users\KKozlows\Documents\Arduino\sketch_jul03a\sketch_jul03a.ino:4:0:
sketch_jul03a:196: error: no match for call to '(ESP8266WebServer) (char&)'
sketch_jul03a:198: error: converting to 'const String' from initializer list would use explicit constructor 'String::String(int, unsigned char)'
exit status 1
option enabled in File -> Preferences.
