ok so i just got 2 xbees and two shieds today but somthing happened plz i beg of you guys plz send a way so i can physically talk to you to my email: njkl44@gmail.com plz its urgent and ill credit you
Ok, so what are you actually wanting to do?
Posting your email like that is just a great way to get a funk load of spam.
god members just means we like to run our mouths
as already mentioned you just singed up for a bucket ton of spam by posting your raw email address
we don't roll like that, what are you trying to do, and why should we keep it hidden from the GP so when someone else has this magic issue we don't have to start over again
personally I check my email once a day, I check this forum every time I sit at the computer, what do you think are the better chances?
ok well i need this solved quick i build an xbee shield from a kit put the x bee on it and was working when i tried to update the firmware it stopped working (light stopped blinking) and does not work i tried it with my other one and worked fine i really cant aford to get anopther one so plz help thank you
You are going to waste everyone's time (I thought you said you were in a hurry?) by NOT identifying everything you are using. Do you want us to just guess? If you are in such a hurry, err on the side of too MUCH data. Else we will be here all day playing 20 questions.
You probably need to unupdate the firmware and be quick about it!
hahah ya i wish but the xbee shield and xbee arnt even wokin the led isnt flashing and isnt getting picked up by X-CTU pretty much the xbee is dead for some reason??
Copy and pasting a previous post of yours does not add any more information.
If you wish, I will email you my phone number, I charge $250 dollars per half-hour for my consulting services, 2 hour minimum and pre-paid orders only.
Or...
You could post how you have connected things, any schematics you have used, what other hardware is involved, and YOUR CODE!
ok that cheap for me
ok so i connected the xbee with the same shield and xbee like this to the arduino except i have the rx conneted to rx and same with the tx:
so ya as i was updating the firmware it just stopped
Then perhaps it's dead. You said you had two, have you tried the other?
ya i have tried the other one and it works fien with the shield but i really need to get this one working i really cant buy another one
Well, if one works, and the other doesn't (assuming they are wired the same), my bets would be on a dead unit.
is there any way to fix that
Talk with the store you purchased it from and have them issue a replacement.
Buy a new one.
Fix it your self, however (with all due respect) if you have to ask, you likely won't be able to fix it yourself.
haha, try an xbee reset... No I'm not going to tell you how to do that - LOOK IT UP YOURSELF.
@nickvd - Hey, you're not a god member....
The data sheet I am reading says 3.3 volts. It looks like you are feeding it 5V?
the board on the bottom has a level converter and voltage regulator
So how do I reset it
