Please check this millisecond adjustment method to Time.h
Hi All,
This is the latest Time.h, with adjustTimeMS() method added. I did this because I have several clocks close to each other, and because the time library deals only with seconds, they could not easily be precisely synchronized. With this I can use the centisecond() method of TinyGPS++ to synchronize to 1/100 seconds. Another way to do it is to add one second to time, then delay one second - gps.time.centiseconds()* 10 before setting the time, but this seems much cleaner.
Also, with this method, gps.time.age() can be added in ms, to more precisely set the time:
adjustTimeMS(gps.time.centisecond() * 10 + gps.time.age())
I’ve removed some code below the modifications because the message exceeded the maximum allowed length.
Please search for the variable, msInterval, and the method above, and let me know if you see a better way to do this, and also if you see any unintended consequences. Without extensive testing it does appear to work as designed. Thank you.
  time.c - low level time and date functions
  Copyright (c) Michael Margolis 2009-2014
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
  1.0  6  Jan 2010 - initial release
  1.1  12 Feb 2010 - fixed leap year calculation error
  1.2  1  Nov 2010 - fixed setTime bug (thanks to Korman for this)
  1.3  24 Mar 2012 - many edits by Paul Stoffregen: fixed timeStatus() to update
                     status, updated examples for Arduino 1.0, fixed ARM
                     compatibility issues, added TimeArduinoDue and TimeTeensy3
                     examples, add error checking and messages to RTC examples,
                     add examples to DS1307RTC library.
  1.4  5  Sep 2014 - compatibility with Arduino 1.5.7
#if ARDUINO >= 100
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
#include "Time.h"
static tmElements_t tm;          // a cache of time elements
static time_t cacheTime;   // the time the cache was updated
static uint32_t syncInterval = 300;  // time sync will be attempted after this many seconds
static int msInterval =0;
void refreshCache(time_t t) {
  if (t != cacheTime) {
    breakTime(t, tm);
    cacheTime = t;
int hour() { // the hour now
  return hour(now());
int hour(time_t t) { // the hour for the given time
  refreshCache(t);
  return tm.Hour;
int hourFormat12() { // the hour now in 12 hour format
  return hourFormat12(now());
int hourFormat12(time_t t) { // the hour for the given time in 12 hour format
  refreshCache(t);
  if( tm.Hour == 0 )
    return 12; // 12 midnight
  else if( tm.Hour  > 12)
    return tm.Hour - 12 ;
    return tm.Hour ;
uint8_t isAM() { // returns true if time now is AM
  return !isPM(now());
uint8_t isAM(time_t t) { // returns true if given time is AM
  return !isPM(t);
uint8_t isPM() { // returns true if PM
  return isPM(now());
uint8_t isPM(time_t t) { // returns true if PM
  return (hour(t) >= 12);
int minute() {
  return minute(now());
int minute(time_t t) { // the minute for the given time
  refreshCache(t);
  return tm.Minute;
int second() {
  return second(now());
int second(time_t t) {  // the second for the given time
  refreshCache(t);
  return tm.Second;
int day(){
  return(day(now()));
int day(time_t t) { // the day for the given time (0-6)
  refreshCache(t);
  return tm.Day;
int weekday() {   // Sunday is day 1
  return  weekday(now());
int weekday(time_t t) {
  refreshCache(t);
  return tm.Wday;
int month(){
  return month(now());
int month(time_t t) {  // the month for the given time
  refreshCache(t);
  return tm.Month;
int year() {  // as in Processing, the full four digit year: (2009, 2010 etc)
  return year(now());
int year(time_t t) { // the year for the given time
  refreshCache(t);
  return tmYearToCalendar(tm.Year);
/* functions to convert to and from system time */
/* These are for interfacing with time serivces and are not normally needed in a sketch */
// leap year calulator expects year argument as years offset from 1970
#define LEAP_YEAR(Y)     ( ((1970+Y)>0) && !((1970+Y)%4) && ( ((1970+Y)%100) || !((1970+Y)%400) ) )
static  const uint8_t monthDays[]={31,28,31,30,31,30,31,31,30,31,30,31}; // API starts months from 1, this array starts from 0
void breakTime(time_t timeInput, tmElements_t &tm){
// break the given time_t into time components
// this is a more compact version of the C library localtime function
// note that year is offset from 1970 !!!
  uint8_t year;
  uint8_t month, monthLength;
  uint32_t time;
  unsigned long days;
  time = (uint32_t)timeInput;
  tm.Second = time % 60;
  time /= 60; // now it is minutes
  tm.Minute = time % 60;
  time /= 60; // now it is hours
  tm.Hour = time % 24;
  time /= 24; // now it is days
  tm.Wday = ((time + 4) % 7) + 1;  // Sunday is day 1
  year = 0;
  days = 0;
  while((unsigned)(days += (LEAP_YEAR(year) ? 366 : 365)) <= time) {
    year++;
  tm.Year = year; // year is offset from 1970
  days -= LEAP_YEAR(year) ? 366 : 365;
  time  -= days; // now it is days in this year, starting at 0
  days=0;
  month=0;
  monthLength=0;
  for (month=0; month<12; month++) {
    if (month==1) { // february
      if (LEAP_YEAR(year)) {
        monthLength=29;
        monthLength=28;
      monthLength = monthDays[month];
    if (time >= monthLength) {
      time -= monthLength;
  tm.Month = month + 1;  // jan is month 1
  tm.Day = time + 1;     // day of month
time_t makeTime(tmElements_t &tm){
// assemble time elements into time_t
// note year argument is offset from 1970 (see macros in time.h to convert to other formats)
// previous version used full four digit year (or digits since 2000),i.e. 2009 was 2009 or 9
  int i;
  uint32_t seconds;
  // seconds from 1970 till 1 jan 00:00:00 of the given year
  seconds= tm.Year*(SECS_PER_DAY * 365);
  for (i = 0; i < tm.Year; i++) {
    if (LEAP_YEAR(i)) {
      seconds +=  SECS_PER_DAY;   // add extra days for leap years
  // add days for this year, months start from 1
  for (i = 1; i < tm.Month; i++) {
    if ( (i == 2) && LEAP_YEAR(tm.Year)) {
      seconds += SECS_PER_DAY * 29;
      seconds += SECS_PER_DAY * monthDays[i-1];  //monthDay array starts from 0
  seconds+= (tm.Day-1) * SECS_PER_DAY;
  seconds+= tm.Hour * SECS_PER_HOUR;
  seconds+= tm.Minute * SECS_PER_MIN;
  seconds+= tm.Second;
  return (time_t)seconds;
/* Low level system time functions  */
static uint32_t sysTime = 0;
static uint32_t prevMillis = 0;
static uint32_t nextSyncTime = 0;
static timeStatus_t Status = timeNotSet;
getExternalTime getTimePtr;  // pointer to external sync function
//setExternalTime setTimePtr; // not used in this version
#ifdef TIME_DRIFT_INFO   // define this to get drift data
time_t sysUnsyncedTime = 0; // the time sysTime unadjusted by sync
#endif
time_t now() {
 // calculate number of seconds passed since last call to now()
  while (millis() - prevMillis >= 1000 + msInterval) {
 // millis() and prevMillis are both unsigned ints thus the subtraction will always be the absolute value of the difference
    sysTime++;
    prevMillis = prevMillis + 1000 + msInterval;
    msInterval = 0;
    sysUnsyncedTime++; // this can be compared to the synced time to measure long term drift
#endif
  if (nextSyncTime <= sysTime) {
    if (getTimePtr != 0) {
      time_t t = getTimePtr();
      if (t != 0) {
        setTime(t);
        nextSyncTime = sysTime + syncInterval;
        Status = (Status == timeNotSet) ?  timeNotSet : timeNeedsSync;
  return (time_t)sysTime;
