Please corect this code
#include <AFMotor.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
#define MAX_DISTANCE 200
#define MAX_SPEED 190 // sets speed of DC motors
#define MAX_SPEED_OFFSET 20
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(3, MOTOR12_1KHZ);
Servo myservo;
myservo.attach(9);
myservo.write(115);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100); // put your setup code here, to run once:
int distanceR = 0;
int distanceL = 0;
delay(40);
if(distance<=15)
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
distanceR = lookRight();
delay(200);
distanceL = lookLeft();
delay(200);
if(distanceR>=distanceL)
turnRight();
moveStop();
}else
turnLeft();
moveStop();
“it is coming”:exit status 1
AFMotor.h: No such file or directory
i am making an onbstacle avoiding 2 wheeled car
Do you have the AFMotor library installed and if so, where is it located on your PC ?
where can i download the following library’
Is Google broken today ?
thank you it worked
but another error popped up
at the last line of the code it says
distance’ was not declared in this scope
please reply i will be gratefull to you
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
Servo myservo;
myservo.attach(9);
myservo.write(115);
delay(2000);
delay(100);
delay(100);
delay(100);
int distanceR = 0;
int distanceL = 0;
delay(40);
if(distance<=15)
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
delay(200);
delay(200);
turnRight();
moveStop();
}else
turnLeft();
moveStop();
}else
moveForward();
}// put your main code here, to run repeatedly:
“this is the real code”
Is the compiler telling the truth ?
Where is distance declared ?
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
Servo myservo;
myservo.attach(9);
myservo.write(115);
delay(2000);
delay(100);
delay(100);
delay(100);
int distanceR = 0;
int distanceL = 0;
delay(40);
if(distance<=15)
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
delay(200);
delay(200);
turnRight();
moveStop();
}else
turnLeft();
moveStop();
}else
moveForward();
<distance = readPing();>
i put {<>} where the error code is
I note that you have ignored the advice to use code tags when posting code
So, where is distance declared in your code ?
i did not understand what code tags are
i am a starter to arduino
You don’t even need to know what they are if you follow the advice in the link
  • In the Arduino IDE under the ‘Edit’ menu there is ‘Copy for Forum’, this puts your code on the clipboard with code tags added ready to paste into your question.
let me try
I also suggest that you post your complete code; there seem to be missing functions like moveStop(), turnLeft() etc.
I don’t think you understand how to use NewPing either.
Have you written your code in stages?
You should have some code that JUST reads from the Ultrasonic.
You should have code that JUST controls the motors.
THEN when you have each bit of code working, you put them together.
So where is your code for the Ultrasonic?
Where is your code JUST to control the motor shield?
Is this a school project/assignment?
Thanks… Tom… :smiley: :+1: :australia:
PS, this how your NewPing code should look, it is nothing like what you have coded.
// Example NewPing library sketch that does a ping about 20 times per second.
#define TRIGGER_PIN  12  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     11  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
  Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
  delay(50);                     // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  Serial.print("Ping: ");
  Serial.print(sonar.ping_cm()); // Send ping, get distance in cm and print result (0 = outside set distance range)
  Serial.println("cm");
Could you please tell the changes i should do in my code
here is the complete code
[code]
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
Servo myservo;
 myservo.attach(9);
  myservo.write(115);
  delay(2000);
  delay(100);
  delay(100);
  delay(100);
  int distanceR = 0;
 int distanceL =  0;
 delay(40);
 if(distance<=15)
  moveStop();
  delay(100);
  moveBackward();
  delay(300);
  moveStop();
  delay(200);
  delay(200);
  delay(200);
    turnRight();
    moveStop();
  }else
    turnLeft();
    moveStop();
}else
  moveForward();
[/code]type or paste code here
