please could anyone help me with this code i want to make a voice remote
please could anyone help me with this code i want to make a voice controlled remote could someone see and correct the code plz
#include <IRremote.h>
#include <SoftwareSerial.h>
#include "VoiceRecognitionV3.h"
byte com = 0; //reply from voice recognition
VR myVR(2,5);
IRsend irsend;
Serial.write(0xAA);
Serial.write(0x11);
Serial.write(0xAA);
Serial.write(0x12);
    int khz = 38; // 38kHz carrier frequency for the NEC protocol
  unsigned int irSignal[] = {9150,4400,600,550,650,450,700,450,650,500,650,450,700,450,650,450,700,450,650,1600,700,1550,700,1600,650,1600,650,1600,650,1600,700,1550,700,1600,650,450,700,1550,700,450,650,500,650,1600,650,450,700,450,700,450,650,1600,650,500,650,1600,650,1600,650,500,650,1600,650,1600,650,1600,700}; //AnalysIR Batch Export (IRremote) - RAW
while(Serial.available())
com = Serial.read();
switch(com)
case 0x11:
  irsend.sendRaw(irSignal, sizeof(irSignal) / sizeof(irSignal[0]), khz); //Note the approach used to automatically calculate the size of the array.
Voice_control_1.ino (975 Bytes)
please i have an important project depend on this code ;(
What's the problem?
im new with arduino :( the pin of ir led is not declared
Moderator edit: excessive white space removed.
Why didn't you declare it?
seriously i dont know how to declare it
What is the full error message that you get when you try to compile the code ?
there is no error in the code put i dont know the pin of the ir led
Which pin is it connected to ?
i want to connect it to pin 9
hamza95:
Have you tried connecting it ? What happens ? Have you looked at the IRremote examples ? How will the program know which pin you are using ? What is the remote supposed to do ?
UKHeliBob: Have you tried connecting it ? What happens ? Have you looked at the IRremote examples ? How will the program know which pin you are using ? What is the remote supposed to do ?
this is the main issue that i faced
Why did you start a new thread on the same subject ?
