Hi there.So im hoping that any of you could help me recognizing and solve the problem here.I kinda have a problem to settle it by myself,no its more to that im a beginner and i am lost of any other way to solve it and the more important thing is the due date is coming heh.
I copied this programming from
https://howtomechatronics.com/projects/arduino-touch-screen-music-player-alarm-clock-project/
but the there is one component that i change and that is BY8001 to DFPlayer so i have to change the BY8001 coding to DFPlayer .
This is the link to the DFPLayer code : DFPlayer_Mini_SKU_DFR0299-DFRobot
And this is one that i have change for a bit
[code]
Arduino Touch Screen MP3 Music Player and Alarm Clock
Crated by Dejan Nedelkovski,
www.HowToMechatronics.com
UFTF, URTouch and DS3231 libraries made by Henning Karlsen which can be found and downloaded from his website, www.rinkydinkelectronics.com.
BY8001 MP3 Player Library made by borland of Arduino forum, Released in public domain. Dowload link: https://github.com/r0ndL/BY8001
#include <UTFT.h>
#include <URTouch.h>
#include <SoftwareSerial.h>
#include <DFRobotDFPlayerMini.h>
#include <DS3231.h>
#include <Arduino.h>
//==== Creating Objects
UTFT myGLCD(SSD1289, 38, 39, 40, 41); //Parameters should be adjusted to your Display/Schield model
URTouch myTouch( 6, 5, 4, 3, 2);
SoftwareSerial mp3Serial(11, 10); // RX, TX
DFRobotDFPlayerMini myDFPlayer; //
DS3231 rtc(SDA, SCL);
void printDetail(uint8_t type, int value);
//==== Defining Fonts
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
extern unsigned int MusicPlayerButton[0x1040];
extern unsigned int AlarmButton[0x1040];
extern unsigned int ButtonPlay[0x1AE9];
extern unsigned int ButtonPause[0x1AE9];
extern unsigned int PreviousButton[0x9C4];
extern unsigned int NextButton[0x9C4];
extern unsigned int VolumeDown[0x170];
extern unsigned int VolumeUp[0x3B8];
int x, y; // Variables for the coordinates where the display has been pressed
char currentPage, playStatus;
int iV = 15;
int trackNum = 1;
int b = 16;
int aHours = 0;
int aMinutes = 0;
boolean alarmNotSet = true;
String alarmString = "";
float currentTemperature, temperature;
static word totalTime, elapsedTime, playback, minutes, seconds, lastSeconds, minutesR, secondsR;
String currentClock, currentHours, currentMinutes, currentSeconds, currentDate;
String timeString, hoursString, minutesString, secondsString, hoursS, minutesS, secondsS, dateS;
// Initiate display
myGLCD.InitLCD();
myGLCD.clrScr();
myTouch.InitTouch();
myTouch.setPrecision(PREC_MEDIUM);
// Initialize the rtc object
rtc.begin();
// Music
Serial.begin(9600); // set serial monitor baud rate to Arduino IDE
mp3Serial.begin(9600); // BY8001 set to 9600 baud (required)
myDFPlayer.begin(mp3Serial); // tell BY8001 library which serial port to use.
delay(800); // allow time for BY8001 cold boot; may adjust depending on flash storage size
drawHomeScreen(); // Draws the Home Screen
currentPage = '0'; // Indicates that we are at Home Screen
playStatus = '0';
myDFPlayer.volume(15);
delay(100);
currentTemperature = rtc.getTemp();
currentDate = rtc.getDateStr();
currentClock = rtc.getTimeStr();
timeString = rtc.getTimeStr();
currentHours = timeString.substring(0, 2);
currentMinutes = timeString.substring(3, 5);
currentSeconds = timeString.substring(6, 8);
// Homes Screen
if (currentPage == '0') {
// Checks for change of the clock
if ( currentClock != rtc.getTimeStr()) {
hoursS = timeString.substring(0, 2);
minutesS = timeString.substring(3, 5);
secondsS = timeString.substring(6, 8);
myGLCD.setFont(SevenSegNumFont);
myGLCD.setColor(0, 255, 0);
myGLCD.print(secondsS, 224, 50);
if ( currentMinutes != minutesS ) {
myGLCD.print(minutesS, 128, 50);
currentMinutes = minutesS;
if ( currentHours != hoursS ) {
myGLCD.print(hoursS, 32, 50);
currentHours = hoursS;
// Checks for change of the date
dateS = rtc.getDateStr();
delay(10);
if ( currentDate != dateS) {
myGLCD.setColor(255, 255, 255); // Sets color to white
myGLCD.setFont(BigFont); // Sets font to big
myGLCD.print(rtc.getDateStr(), 153, 7);
// Checks for change of the temperature
temperature = rtc.getTemp();
delay(10);
if ( currentTemperature != temperature ) {
myGLCD.printNumI(temperature, 39, 7);
currentTemperature = temperature;
delay(10);
// Checks whether the screen has been touched
if (myTouch.dataAvailable()) {
myTouch.read();
x = myTouch.getX(); // X coordinate where the screen has been pressed
y = myTouch.getY(); // Y coordinates where the screen has been pressed
// If we press the Music Player Button
if ((x >= 55) && (x <= 120) && (y >= 125) && (y <= 190)) {
drawFrame(87, 157, 33);
currentPage = '1';
myGLCD.clrScr();
delay(100);
drawMusicPlayerScreen();
delay(100);
// If we press the Alarm Button
if ((x >= 195) && (x <= 260) && (y >= 125) && (y <= 190)) {
drawFrame(227, 160, 29);
currentPage = '2';
myGLCD.clrScr();
// Music Player Screen
if (currentPage == '1') {
myTouch.read();
// If we press the Play Button
if ((x >= 116) && (x <= 204) && (y >= 77) && (y <= 165)) {
if (playStatus == '0') {
drawFrame(159, 121, 42);
drawPauseButton();
myDFPlayer.playFolder(15, 4); //play specific mp3 in SD:/15/004.mp3; Folder Name(1~99); File Name(1~255)
delay(100);
playStatus = '2';
return;
if (playStatus == '1') {
drawPauseButton();
myDFPlayer.play();
delay(100);
playStatus = '2';
return;
if (playStatus == '2') {
drawPlayButton();
myDFPlayer.pause();
delay(100);
playStatus = '1';
return;
// If we press the Previous Button
if ((x >= 45) && (x <= 95) && (y >= 97) && (y <= 147)) {
drawFrame(70, 121, 26);
myDFPlayer.previous();
delay(100);
drawTrackBar();
// If we press the Next Button
if ((x >= 227) && (x <= 277) && (y >= 97) && (y <= 147)) {
drawFrame(252, 122, 26);
myDFPlayer.next();
delay(100);
drawTrackBar();
// If we press the VolumeDown Button
if ((x >= 35) && (x <= 75) && (y >= 165) && (y <= 209)) {
drawUnderline(45, 205, 65, 205);
if (iV >= 0 & iV <= 30) {
iV--;
drawVolumeDown();
myDFPlayer.volumeDown();
delay(100);
// If we press the VolumeUp Button
if ((x >= 230) && (x <= 280) && (y >= 165) && (y <= 209)) {
drawUnderline(235, 205, 275, 205);
iV++;
drawVolumeUp();
myDFPlayer.volumeUp();
delay(100);
// If we press the MENU Button
if ((x >= 0) && (x <= 75) && (y >= 0) && (y <= 30)) {
myGLCD.clrScr();
currentPage = '0';
return;
// Updates the track bar
if (playStatus == '1' || playStatus == '2') {
trackPlayTime();
// Printing the clock in the upper right corner
currentClock(187, 5);
// Alarm Clock Screen
if (currentPage == '2') {
myGLCD.print("MENU", 5, 5);
myGLCD.print("Set Alarm", CENTER, 20);
// Draws a colon between the hours and the minutes
myGLCD.fillCircle (112, 65, 4);
myGLCD.fillCircle (112, 85, 4);
myGLCD.printNumI(aHours, 32, 50, 2, '0');
myGLCD.printNumI(aMinutes, 128, 50, 2, '0');
myGLCD.drawRoundRect (42, 115, 82, 145);
myGLCD.drawRoundRect (138, 115, 178, 145);
myGLCD.print("H", 54, 122);
myGLCD.print("M", 150, 122);
myGLCD.drawRoundRect (215, 60, 303, 90);
myGLCD.print("SET", 236, 67);
myGLCD.drawRoundRect (215, 115, 303, 145);
myGLCD.print("CLEAR", 220, 122);
alarmNotSet = true;
while (alarmNotSet) {
myTouch.read();
//Set hours button
if ((x >= 42) && (x <= 82) && (y >= 115) && (y <= 145)) {
drawRectFrame(42, 115, 82, 145);
aHours++;
if (aHours >= 24) {
aHours = 0;
// Set minutes buttons
if ((x >= 138) && (x <= 178) && (y >= 115) && (y <= 145)) {
drawRectFrame(138, 115, 178, 145);
aMinutes++;
if (aMinutes >= 60) {
aMinutes = 0;
// Set alarm button
if ((x >= 215) && (x <= 303) && (y >= 60) && (y <= 80)) {
drawRectFrame(215, 60, 303, 90);
if (aHours < 10 && aMinutes < 10) {
alarmString = "0" + (String)aHours + ":" + "0" + (String)aMinutes + ":" + "00";
else if (aHours < 10 && aMinutes > 9) {
alarmString = "0" + (String)aHours + ":" + (String)aMinutes + ":" + "00";
else if (aHours > 9 && aMinutes < 10) {
alarmString = (String)aHours + ":" + "0" + (String)aMinutes + ":" + "00";
else {
alarmString = (String)aHours + ":" + (String)aMinutes + ":" + "00";
myGLCD.print("Alarm set for:", CENTER, 165);
myGLCD.print(alarmString, CENTER, 191);
// Clear alarm button
if ((x >= 215) && (x <= 303) && (y >= 115) && (y <= 145)) {
drawRectFrame(215, 115, 303, 145);
alarmString = "";
myGLCD.setColor(0, 0, 0);
myGLCD.fillRect(45, 165, 275, 210);
alarmNotSet = false;
currentPage = '0';
myGLCD.clrScr();
// Alarm activation
if (alarmNotSet == false) {
if (alarmString == rtc.getTimeStr()) {
myGLCD.clrScr();
myDFPlayer.volume(25);
myDFPlayer.play(1);
delay(100);
myGLCD.print("ALARM", CENTER, 90);
myGLCD.drawBitmap (127, 10, 65, 64, AlarmButton);
myGLCD.print(alarmString, CENTER, 114);
myGLCD.drawRoundRect (94, 146, 226, 170);
myGLCD.print("DISMISS", CENTER, 150);
boolean alarmOn = true;
while (alarmOn) {
myTouch.read();
// Stop alarm button
if ((x >= 94) && (x <= 226) && (y >= 146) && (y <= 170)) {
drawRectFrame(94, 146, 226, 170);
alarmOn = false;
alarmString = "";
myGLCD.clrScr();
myDFPlayer.stop();
delay(100);
currentPage = '0';
playStatus = '0';
drawHomeScreen();
void drawHomeScreen() {
myGLCD.setBackColor(0, 0, 0); // Sets the background color of the area where the text will be printed to black
myGLCD.print("T:", 7, 7);
myGLCD.printNumI(rtc.getTemp(), 39, 7);
myGLCD.print("C", 82, 7);
myGLCD.setFont(SmallFont);
myGLCD.print("o", 74, 5);
if (alarmString == "" ) {
myGLCD.print("n u h a f a", CENTER, 215);
else {
myGLCD.print("Alarm set for: ", 68, 215);
myGLCD.print(alarmString, 188, 215);
drawMusicPlayerButton();
drawAlarmButton();
drawHomeScreen();
void drawMusicPlayerScreen() {
// Title
myGLCD.print("MENU", 5, 5); // Prints the string on the screen
myGLCD.setColor(255, 0, 0); // Sets color to red
myGLCD.drawLine(0, 26, 319, 26); // Draws the red line
myGLCD.setFont(SmallFont); // Sets font to big
myGLCD.print("n u h a f a", CENTER, 215); // Prints the string on the screen
// Volume Bar
myGLCD.fillRect (78, 184, 78 + 150, 184 + 8);
myGLCD.setColor(240, 196, 30);
myGLCD.fillRect (78, 184, 78 + 75, 184 + 8);
// Track Bar
myGLCD.fillRect (48, 50, 48 + 224, 50 + 8);
myGLCD.print("0:00", 8, 48);
myGLCD.print("-0:00", 276, 48);
drawPlayButton();
drawPauseButton();
drawPreviousButton();
drawNextButton();
drawVolumeDown();
drawVolumeUp();
void drawMusicPlayerButton() {
myGLCD.drawBitmap (55, 125, 65, 64, MusicPlayerButton);
void drawAlarmButton() {
myGLCD.drawBitmap (195, 125, 65, 64, AlarmButton);
void drawPlayButton() {
myGLCD.drawBitmap (118, 79, 83, 83, ButtonPlay);
void drawPauseButton() {
myGLCD.drawBitmap (118, 79, 83, 83, ButtonPause);
void drawNextButton() {
myGLCD.drawBitmap (227, 97, 50, 50, NextButton);
void drawPreviousButton() {
myGLCD.drawBitmap (45, 97, 50, 50, PreviousButton);
void drawVolumeDown() {
myGLCD.drawBitmap (50, 177, 16, 23, VolumeDown);
void drawVolumeUp() {
myGLCD.drawBitmap (241, 175, 34, 28, VolumeUp);
// check for if Mp3 Player is stopped
bool checkFor_mp3IsStopped() {
if (myDFPlayer.available() > 0) {
if printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
return true;
else return false;
// Highlights the button when pressed
void drawFrame(int x, int y, int r) {
myGLCD.drawCircle (x, y, r);
while (myTouch.dataAvailable())
myTouch.read();
void drawRectFrame(int x1, int y1, int x2, int y2) {
myGLCD.drawRoundRect (x1, y1, x2, y2);
myTouch.read();
void drawUnderline(int x1, int y1, int x2, int y2) {
myGLCD.drawLine (x1, y1, x2, y2);
myTouch.read();
// Sound bar
void drawVolume(int x) {
myGLCD.fillRect (78 + 5 * x, 184, 78 + 150, 184 + 8);
myGLCD.fillRect (78, 184, 78 + 5 * x, 184 + 8);
// Clears the track bar
void drawTrackBar() {
void trackPlayTime() {
totalTime = myDFPlayer.getTotalTrackPlaybackTime();
delay(10);
elapsedTime = myDFPlayer.getElapsedTrackPlaybackTime();
delay(10);
minutes = (int)elapsedTime / 60;
seconds = (((float)elapsedTime / 60) - minutes) * 60;
playback = totalTime - elapsedTime;
minutesR = (int)playback / 60;
secondsR = (((float)playback / 60) - minutesR) * 60;
myGLCD.printNumI(minutes, 8, 48);
myGLCD.print(":", 16, 48);
myGLCD.printNumI((int)seconds, 24, 48, 2, '0');
myGLCD.print("-", 276, 48);
myGLCD.printNumI(minutesR, 284, 48);
myGLCD.print(":", 292, 48);
myGLCD.printNumI((int)secondsR, 300, 48, 2, '0');
int trackBarX = map(elapsedTime, 0, totalTime, 0, 224);
myGLCD.fillRect (48, 50, 48 + trackBarX, 50 + 8);
if (totalTime == elapsedTime) {
myDFPlayer.next();
delay(30);
void printClock(int x, int y) {
myGLCD.print(rtc.getTimeStr(), x, y);
void drawColon() {
myGLCD.fillCircle (208, 65, 4);
myGLCD.fillCircle (208, 85, 4);
void drawHomeClock() {
myGLCD.print(currentSeconds, 224, 50);
myGLCD.print(currentMinutes, 128, 50);
myGLCD.print(currentHours, 32, 50);
drawColon();
[/code]
And this is the error message from the latest prob i got
[code]
Arduino: 1.8.15 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\lenovo\Documents\Arduino\sketch_jun19c\sketch_jun19c.ino: In function 'void loop()':
sketch_jun19c:138:9: error: 'drawFrame' was not declared in this scope
sketch_jun19c:147:9: error: 'drawFrame' was not declared in this scope
sketch_jun19c:163:11: error: 'drawFrame' was not declared in this scope
sketch_jun19c:171:11: error: 'drawFrame' was not declared in this scope
sketch_jun19c:179:11: error: 'drawFrame' was not declared in this scope
sketch_jun19c:189:9: error: 'drawFrame' was not declared in this scope
sketch_jun19c:192:9: error: 'drawTrackBar' was not declared in this scope
drawTrackBar();
sketch_jun19c:196:9: error: 'drawFrame' was not declared in this scope
sketch_jun19c:199:9: error: 'drawTrackBar' was not declared in this scope
drawTrackBar();
sketch_jun19c:203:9: error: 'drawUnderline' was not declared in this scope
sketch_jun19c:213:9: error: 'drawUnderline' was not declared in this scope
sketch_jun19c:231:7: error: 'trackPlayTime' was not declared in this scope
trackPlayTime();
sketch_jun19c:236:24: error: no match for call to '(String) (int, int)'
sketch_jun19c:276:11: error: 'drawRectFrame' was not declared in this scope
sketch_jun19c:287:11: error: 'drawRectFrame' was not declared in this scope
sketch_jun19c:298:11: error: 'drawRectFrame' was not declared in this scope
sketch_jun19c:318:11: error: 'drawRectFrame' was not declared in this scope
sketch_jun19c:357:13: error: 'drawRectFrame' was not declared in this scope
C:\Users\lenovo\Documents\Arduino\sketch_jun19c\sketch_jun19c.ino: In function 'bool checkFor_mp3IsStopped()':
sketch_jun19c:463:8: error: expected '(' before 'printDetail'
C:\Users\lenovo\Documents\Arduino\sketch_jun19c\sketch_jun19c.ino: At global scope:
sketch_jun19c:467:1: error: expected unqualified-id before 'else'
else return false;
sketch_jun19c:468:1: error: expected declaration before '}' token
exit status 1
[/code]
You can just point out every mistake i did soo,
Please do help me.My due date is coming and im stuck here hoho
Thanks for advance
