No. You only have 2 outputs (A & B) and (Z & Y). See bottom of page 19. Differential line drive requires two lines, not one line and a ground. If you're not familiar with that you should read the following before using RS422.
RS422 is 5V differential line drive. The outputs on page 21 are either A & B OR Z & Y (as Mike stated).
Unlike TTL, the signal is transferred on TWO wires, not ONE. A & B is the signal names for a single driver. The one on page 21 appears to be digital switched 1-to -2 adaptor. Only one can be active at a time.
