here is my codes
receiver
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
int ledPin = 13;
unsigned long last = millis();//set timer
mySerial.begin(9600);
pinMode(ledPin, OUTPUT);
boolean ledState = digitalRead(ledPin);//check if the LED is turned on or off. Returns 1 or 0
if(mySerial.available() > 1){
int input = mySerial.parseInt();//read serial input and convert to integer (-32,768 to 32,767)
if(millis() - last > 250){//if time now is 250 milliseconds greater than last time
if(ledState == 0 && input == 1234){//if LED is off and button code is ok
digitalWrite(ledPin, HIGH);
}else if(ledState == 1 && input == 1234){//if LED is on and button code is ok
digitalWrite(ledPin, LOW);
mySerial.flush();//clear the serial buffer for unwanted inputs
last = millis();//reset timer
delay(20);//delay little for better serial communication
SENDER
//HC-12 Toggle button Send
//Autor Tom Heylen tomtomheylen.com
SoftwareSerial mySerial(2, 3); //RX, TX
int buttonPin = 8;
pinMode(buttonPin, INPUT);
int buttonState = digitalRead(buttonPin);
if(buttonState == 1){//if button is down
mySerial.println(1234);//send unique code to the receiver in this case 1234
