Hi, everyone. I’m a beginner
Pls help, can change massage all to lower string?
How can I do it?
Arduino recieve message from GSM Module. And i need to change its all to lower string. Now, I use message library.
#include <Messenger.h>
#include <String.h>
#include <stdio.h>
// Instantiate Messenger object with the message function and the default separator
// (the space character)
Messenger message = Messenger();
// Define messenger function
void messageCompleted() {
Message = Message.ToLower();
// This loop will echo each element of the message separately
while ( message.available() ) {
if ( message.checkString(“on”) ) {
digitalWrite(13,HIGH);
} else if ( message.checkString(“of”) ) {
digitalWrite(52,HIGH);
} else if ( message.checkString(“off”) ) {
digitalWrite(13,LOW);
} else if ( message.checkString(“ooff”) ) {
digitalWrite(52,LOW);
break; }
// Initiate Serial Communication
message.attach(messageCompleted);
pinMode(13,OUTPUT);
pinMode(52,OUTPUT);
// The following line is the most effective way of
// feeding the serial data to Messenger
while ( Serial.available() ) message.process( Serial.read() );
Above codes won’t work.
Thanks advance.
