Please help: Arduino mega 2560 avrdude: stk500v2_ReceiveMessage(): timeout
I am completeley new to arduino and am really frustrated. I have no been able to download a single program to my board. I have been reading stuff for a week now. There is so much information about arduino that it is hard to find meaningful answers.
I have Ubuntu 10.10 and Ubuntu 10.04. I downloaded the latest software (1.0.1).
When I connect the board to USB led 13 blinks for a second as if the board has loaded the blink program as a test.
When I try to program I do see the Tx and Rx blink for a sec... but nothing happens.
Tools -> Boards -> Arduino Mega 2560 ADK (there is no other 2560 on the list)
Serial port is on /dev/ttyACM0
Programmer -> AVRISP mkii (I only have the mega board connected to my laptop, no programmer at all). I am wondering what all these options mean, but have not found answers. This is the option that came in by default.
I also built a paralell cable thinking that this may be a bootloader problem... but is it?
Also I use linux on my desktop (ubuntu 10.04)... how would I burn it from there? All I have seen are windows solutions.
Thank you very much... here is the log of the upload:
/home/pastito/arduino-1.0.1/hardware/tools/avrdude -C/home/pastito/arduino-1.0.1/hardware/tools/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P/dev/ttyACM0 -b115200 -D -Uflash:w:/tmp/build3237030616620613547.tmp/led_pde.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 7 2011 at 19:34:16
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/home/pastito/arduino-1.0.1/hardware/tools/avrdude.conf"
User configuration file is "/home/pastito/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: ser_recv(): programmer is not responding
avrdude: stk500v2_getsync(): timeout communicating with programmer
AVR Part : ATMEGA2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500 Version 2.x firmware
Programmer Model: Unknown
avrdude: Send: . [1b] . [01] . [00] . [02] . [0e] . [03] . [90] . [85]
You are no alone. Please refer to the other Mega2560 thread which should be just under or above this thread.
I have read the threads, but my case seems a little different. I do not get the resp=0x00 in the log.
Also I did a loopback test and it works. I send a letter through minicom (serial program) and see the Tx and RX light up and see the echo of the letter on screen.
I will try to re-burn a bootloader with a windows machine. Although I bought arduino to get away from Windows / PIC environment.
I have tried the following:
1.- Modifying the boards.txt
mega2560.upload.protocol=wiring
It does not work. Same errors.
2.- I installed arduino in a PC with Windows XP. Same errors but worse... avrdude hangs and there is no way to kill it
3.- I tried to burn a new bootloader in both windows:
avrdude: AVR device not responding
avrdude: initialization failed, rc=-1
avrdude: Yikes! Invalid device signature.
avrdude: Expected signature for ATMEGA2560 is 1E 98 01
4.- Tried to burn bootloader in linux (Ubuntu 10.04) on AMD64
/home/pastito/arduino-1.0.1/hardware/tools/avrdude -C/home/pastito/arduino-1.0.1/hardware/tools/avrdude.conf -v -v -v -v -patmega2560 -cdapa -F -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 5.11, compiled on Sep 9 2011 at 16:00:41
Using Port : /dev/parport0
Using Programmer : dapa
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Programmer Type : PPI
Description : Direct AVR Parallel Access cable
VCC = 3
BUFF = (not used)
RESET = 16
SCK = 1
MOSI = 2
MISO = 11
ERR LED = 0
RDY LED = 0
PGM LED = 0
VFY LED = 0
avrdude: Calibrating delay loop... calibrated to 166 cycles per us
bitbang_cmd(): [ AC 53 00 00 ] [ FF FF FF FF ]
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
Please help. At this point I am totally frustrated.
can you try version 0023 in windows?
in my pc it solved the problem and i could use the cstk500v2
can you try version 0023 in windows? in my pc it solved the problem and i could use the cstk500v2
Tried that too. No luck.
Just updated the ATMEGA8U2 to rel3... problem persists.
Any ideas?
