Hello!
I am building a heavy duty 3 phase H bridge using only N Channel power MOSFETs
I have bootstrapped the HIGH side FETs according to the schematic that I found on the net.
I use 12v to power the load. This makes the output of the bootstrapping circuit around 24v.
This goes to GATE of the FET.
The control signal is 5v (from Arduino).
Credit for the schematic goes to the original author.
It works pefectly and my N-Channel HIGH side FETs are now fully openable and dont get warm.
I have a problem with the LOW side: FETs get hot very quick.
I would also like to bootstrap the LOW side in exactly the same way.
I have been struggling to modify the above schematic (which is for HIGH side) to be usable on LOW side.
I have been trying different things on breadboard on in LTSpice but with no luck so far.
Could I please have some help bootstrapping the LOW SIDE FETs with a schematic similar to the one above?
I googled around a lot and wasnt able to find anything appropriate. I dont want to use a 555 timing circuit or anything else complicated... Need something very similar to the schematic above, but for LOW side.
Any help and advice would be appreciated.
