Please help can't find software error
Hello I am building a simple output display and I am running into trouble on the code side of things. I have four inputs which accept values of high or low. one works (oil Pressure) but the other three do not register a reading. can anyone see what I am doing wrong? Here is the code
oil pressure Input=0 Output=8
Neutral Input=1 Output=9
High beam Input=2 Output=10
Right Turn Input=3 Output=11
Left Turn Input=4 Output=11
boolean oil = 0;
boolean hBeam = 0;
boolean neu = 0;
boolean turnR = 0;
boolean turnL = 0;
delay(2000);
pinMode(0,INPUT);
pinMode(1,INPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
pinMode(4,INPUT);
pinMode(5,INPUT);
pinMode(6,INPUT);
pinMode(7,INPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
oil = digitalRead(0);
hBeam = digitalRead(1);
neu = digitalRead(2);
turnR = digitalRead(3);
turnL = digitalRead(4);
/Oil Pressure/
if (oil == HIGH)
Serial.println("Oil Pressure Warning!");
delay(2000);
Serial.println("Oil Pressure Normal.");
delay(2000);
/Neutral/
if (neu == HIGH)
Serial.println("Transmission in Neutral");
delay(2000);
Serial.println("Transmission In Gear.");
delay(2000);
/High Beam/
if (hBeam == HIGH)
Serial.println("High Beam On");
delay(2000);
Serial.println("High Beam Off.");
delay(2000);
/Turn Signals/
if (turnR == HIGH || turnL == HIGH)
Serial.println("Turn Signal Active.");
delay(2500);
Serial.println("Turn Signals Off.");
delay(2500);
I would get rid of all those delays and just have one at the end of loop. You are cumulatively delaying after each display.
Also, how are they wired?
You appear to be using pins 0 and 1 for digital I/O and serial I/O.
This is my wiring setup,the finished project will have four of these total, but right now I just use one for testing purposes and connect the "to input pin" wire to the different pins to test the results.
AWOL:
Even after changing the pins i still have the same problem
And we have the problem that we can't see your code or your debug output.
AWOL:
I reverted back to a simple program to eliminate as many factors as possible, I'll try rebuilding the circuit on a different bread board
boolean val = 0;
pinMode(2,INPUT);
val = digitalRead(2);
if (val == HIGH)
Serial.println("opto HI!");
delay(250);
Serial.println("opto LO!");
delay(250);
Ashdricky:
My crystal ball isn't working today, so I'm unable to tell what the unlabelled 6 pin component is, but you could try replacing 'these' with 25A 100V double-acting 6pin thingamybob.
Ashdricky:
And your debug output?
Code tags please.
Read this before posting a programming question
so It turned out that I must have damaged two of the optocouplers as once I replace the two in the circuits that were not functioning all worked well.
