**PLEASE HELP** Code won't verify/compile
Hi, I'm completely new to arduino so really don't know much about how to code or anything. I've been following a tutorial to turn an old toy piano (not digital) into a MIDI controller using Piezos. I'll put a link to the tutorial below.
When I try and compile the sketch I get the following error message -
Build options changed, rebuilding all
/var/folders/dj/f6lqd1yn4kv0w3vffz0ds0940000gn/T/arduino_modified_sketch_439290/AnalogInput.ino:5:18: fatal error: MIDI.h: No such file or directory
 #include <MIDI.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
Here's the code I'm using -
MIDI Toy Piano Hack Code
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
//Values you may need to change
//Set this value to the number of keys/piezos you are using
const int NUM_OF_KEYS = 16;
//Adjust this value to change the sensitivity of the piezos
const int THRESHOLD = 5;
//Set this value to the number of microseconds you want each MIDI note to last for
const int NOTE_LENGTH = 50;
//Adjust this value to set the range of MIDI note velocity values
const int VEL_SENSE_VAL = 2;
//Change this number to set what MIDI channel the MIDI notes are set to
const int midiChan = 1;
//Change these numbers to set what MIDI note number each key/piezo will send.
//Also make sure that the total number of numbers here matches the value of NUM_OF_KEYS
const int midiNote[NUM_OF_KEYS] = {86, 84, 83, 81, 79, 77, 76, 74, 72, 71, 69, 67, 65, 64, 62, 60};
//Change these values to set which analog input pins you are using
//Also make sure that the total number of values here matches the value of NUM_OF_KEYS
const int triggerSensor[NUM_OF_KEYS] = {A0, A1, A2, A3, A4, A5, A6, A7, A8, A9, A10, A11, A12, A13, A14, A15};
//Variables for storing certain values
int triggerVal[NUM_OF_KEYS] = {0};
bool noteIsOn[NUM_OF_KEYS] = {false};
int midiNoteTime[NUM_OF_KEYS] = {0};
int midiVelocityVal[NUM_OF_KEYS] = {0};
    MIDI.begin(MIDI_CHANNEL_OMNI);
    //repeat the below code for each anaolog input/piezo sensor
    for (int count; count < NUM_OF_KEYS; count++)
        //read the piezo value
        triggerVal[count] = analogRead(triggerSensor[count]);
        //if the value is over the threshold and there isn't currently a note on for this piezo
        if (triggerVal[count] > THRESHOLD && noteIsOn[count] == false)
            //get a velocity value based on the value
            midiVelocityVal[count] = triggerVal[count] * (127.0/1023.0);
            //increase sensitivity
            midiVelocityVal[count] *= VEL_SENSE_VAL;
            //make sure we don't go out of range
            if (midiVelocityVal[count] > 127)
            midiVelocityVal[count] = 127;
            //send a MIDI note-on message
            MIDI.sendNoteOn (midiNote[count], midiVelocityVal[count], midiChan);
            //flag that the note is on
            noteIsOn[count] = true;
            //start a timer for the note to be on for
            midiNoteTime[count] = NOTE_LENGTH;
        //if the note is currently on
        if (noteIsOn[count] == true)
            //reduce the time value by 1
            midiNoteTime[count]--;
            //if time value equals 0
            if (midiNoteTime[count] == 0)
                //turn off the note
                MIDI.sendNoteOff (midiNote[count], 0, midiChan);
                noteIsOn[count] = false;
    //pause the loop
    delay(1);
MIDI isn't a default library. Did you download it?
Unfortunately the tutorial author didn't give a link to where you can download the MIDI library but I think I found the right one here in case you haven't installed it already: GitHub - FortySevenEffects/arduino_midi_library: MIDI for Arduino. The second unfortunate thing is the MIDI library author did it wrong so you need to make a modification for the library to be usable:
  • Download https://github.com/FortySevenEffects/arduino_midi_library/archive/master.zip
  • Copy the folder arduino_midi_library-master from the .zip file to the {sketchbook folder}/libraries. To find your sketchbook folder location check File > Preferences > Sketchbook location.
  • Move all files from {sketchbook folder}/libraries/arduino_midi_library-master/src to {sketchbook folder}/libraries/arduino_midi_library-master.
  • Exit and reopen the Arduino IDE if it's running.
After doing that your code compiles for me. Let me know how it goes. Per
pert:
Thanks very much for your quick and very helpful response. I'll try that just now
