Please Help college final Project :(
Anyone can help me to use pn532 on wemos d1???
it cant acces with message "didnt find pn53x board"
  • i have use adafruit pn532 library
  • i use code readmifare with spi communication
please help me :frowning: thanks a lot.....
Check your wiring.
If that doesn't work, follow these instructions.
if i use spi coneection, is it sda scl pin still used? or just the spi component?
SDA/SCL is I2C, not SPI.
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Please post your code.
im soo sory :smiley: im newbie to the forum so i repeat repeat more fully...
okay i use wemos d1 mini pro with pn532 sensor use SPI communication with wiring
sck >>> D5
miso >>> D6
mosi >>> D7
ss >>> D8
RSTO>>> D0
VCC >>> pin 5V wemos
And here is my code:
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
// If using the breakout with SPI, define the pins for SPI communication.
#define PN532_SCK  (D5)
#define PN532_MOSI (D7)
#define PN532_SS   (D8)
#define PN532_MISO (D6)
// If using the breakout or shield with I2C, define just the pins connected
// to the IRQ and reset lines.  Use the values below (2, 3) for the shield!
#define PN532_IRQ   (2)
#define PN532_RESET (D0)  // Not connected by default on the NFC Shield
// Uncomment just _one_ line below depending on how your breakout or shield
// is connected to the Arduino:
// Use this line for a breakout with a SPI connection:
Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
// Use this line for a breakout with a hardware SPI connection.  Note that
// the PN532 SCK, MOSI, and MISO pins need to be connected to the Arduino's
// hardware SPI SCK, MOSI, and MISO pins.  On an Arduino Uno these are
// SCK = 13, MOSI = 11, MISO = 12.  The SS line can be any digital IO pin.
//Adafruit_PN532 nfc(PN532_SS);
// Or use this line for a breakout or shield with an I2C connection:
//Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
void setup(void) {
  while (!Serial) delay(10); // for Leonardo/Micro/Zero
  Serial.println("Hello!");
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // configure board to read RFID tags
  nfc.SAMConfig();
  Serial.println("Waiting for an ISO14443A Card ...");
void loop(void) {
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card");
    Serial.print("  UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
    Serial.print("  UID Value: ");
    nfc.PrintHex(uid, uidLength);
    if (uidLength == 4)
      // We probably have a Mifare Classic card ...
      uint32_t cardid = uid[0];
      cardid <<= 8;
      cardid |= uid[1];
      cardid <<= 8;
      cardid |= uid[2];
      cardid <<= 8;
      cardid |= uid[3];
      Serial.print("Seems to be a Mifare Classic card #");
      Serial.println(cardid);
    Serial.println("");
i use adadfruit library and after upload the code i got the error:
"esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header"
please help me im stuck in my final project
You have also a common ground between the Wemos and the Adafruit_PN532 ?
In any case, post a circuit schematic.
sck >>> D5
miso >>> D6
mosi >>> D7
ss >>> D8
RSTO>>> D0
#include <Wire.h>
#include <SPI.h>
void setup(void) {
  nfc.begin();
    while (1); // halt
  nfc.SAMConfig();
void loop(void) {
  uint8_t success;
  if (success) {
    if (uidLength == 4)
      cardid <<= 8;
      cardid |= uid[1];
      cardid <<= 8;
      cardid |= uid[2];
      cardid <<= 8;
      cardid |= uid[3];
    Serial.println("");
i use adadfruit PN532 library and after upload the code i got the error:
We don't help others to cheat.
duplicate post
https://forum.arduino.cc/index.php?topic=678828.0
Duplicate topics merged
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
ieee488:
Oh, we do, my treasure ....
i use gnd pi from wemos
im sorry im very newbie confused to use this forum and desperate
soo if i just make uncomfortable you guys, im soo sorry maybe ill try the best that i can
what is a "gnd pi"?
sorry i mean gnd pin
I'm glad that the Ground pin is now clear. Can you post your schematic diagram ? A picture of a hand drawn circuit would be fine.
marcani:
That's not after you upload the code, as this means no code can be uploaded to begin with. Something wrong with the connection between your computer and the WeMOS.
Make sure your cable is working properly, and that you have selected the correct interface (ttyusb or com depending on your OS) in the IDE.
