Hello All
Im using a modified 'Knob' sketch to control a GWS125 Winch Servo (A Servo with 1.5 Turns)
I need to control 2-3 of these servos off one UNO board. Can i just duplicate the code underneath, changing the analouge i/p and PWM o/p pin numbers or is there a more efficient shorter way of doing this? I have tried a few things but don't want to get stuck in the wrong direction as time is of the essence. Any help appreciated !
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int potpin = 0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
myservo.attach(9); // attaches the servo on pin 9 to the servo object
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 1000, 1900); // scale it to use it with the servo (value between 0 and 270) - (map values are arbitrary at the moment)
myservo.writeMicroseconds(val); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
i tired duplicating the code with 2 servos plugged in and they just seem to jitter about randomly - is my code wrong?
#include <Servo.h>
Servo myservo2;
int potpin2 = 1; // analog pin used to connect the potentiometer
int val2;
myservo2.attach(10); // attaches the servo on pin 9 to the servo object
val = map(val, 0, 1023, 1000, 1900); // scale it to use it with the servo (value between 0 and 180)
val2 = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val2 = map(val, 0, 1023, 1000, 1900); // scale it to use it with the servo (value between 0 and 180)
myservo2.writeMicroseconds(val); // sets the servo position according to the scaled value
I have now gone back to controlling one servo with the writeMicroseconds() function, tested both servos they are fine. grounds were connected but could have been shoddy i guess .
i was using a bench supply into the breadboard at 5v, this has worked no trouble before with the single servo.
As im writing this I have now altered the code slightly, and am now using the 5v supply that comes on the UNO chip, 2 pots, 2 servos, just tidied it up a bit so i can see whats going on, the potentiometer in analoge pin A0 is controlling the identical movement of both of the servos - i have another pot plugged into pin A1 . PWM should be pin 9 is controlled by A0 and PWM pin 10 Should be controlled by A1. asi said this is at the moment still being powered by the internal power supply.
Here is the code
Ta
#include <Servo.h>
Servo myservo1; // create servo object to control a servo
Servo myservo2;
int val1; // variable to read the value from the analog pin
int val2;
myservo1.attach(9); // attaches the servo on pin 9 to the servo object
val1 = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val1 = map(val1, 0, 1023, 1000, 1900); // scale it to use it with the servo (value between 0 and 180)
myservo1.writeMicroseconds(val1); // sets the servo position according to the scaled value
val2 = map(val2, 0, 1023, 1000, 1900); // scale it to use it with the servo (value between 0 and 180)
myservo2.writeMicroseconds(val2); // sets the servo position according to the scaled value
