Please help debug
Hello.
So I have this code, which makes a servo spin clockwise or counterclockwise, depending on the POT value. And then there is a button, which, when pressed, stops the servo. When the button is not pressed, the servo should keep spinning, but the issue is that HIGH value for the buttons somehow comes on at a constant rate of one second (1 on and 1 off) and stops the servo. So the servo goes on/off/on/off...
Can someone, please have a look and help me find the reason for the HIGH value of the button even when it's not pressed? Here is the code and wiring.
#include <Servo.h>
Servo myservo;
int potpin = A0;
int button = 7;
int potread, servospeed, buttonread;
  myservo.attach(9);
  pinMode(button, INPUT);
  potread = analogRead(potpin);
  servospeed = map(potread, 0, 1023, 0, 179);
  buttonread = digitalRead(button);
  if (buttonread == LOW) {
    myservo.write(servospeed);
    delay(100);
  }else {
    myservo.write(96);
    delay(100);
  Serial.print("POT = ");
  Serial.print(potread);
  Serial.print("\t Mapped POT = ");
  Serial.print(servospeed);
  Serial.print("\t Pin = ");
  Serial.println(buttonread);
  //delay(100);
You need a pulldown or pullup resistor on the button; pullup is easiest with pinMode=(button, INPUT_PULLUP); and then invert your logic since the button will be high until pressed.
JimboZA:
Thank You so much for the input. The pullup resistor worked and now my setup works as intended.
