please help (dis_R = microsecondsToCentimeters(duration);
i've got this message when i type microsecondsToCentimeters(duration)
'microsecondsTocentimeters' was not declared in this scope
#include <SD.h> // need to include the SD library
#include <TMRpcm.h> // library for audio play back
#include <SPI.h>
#include <Wire.h>
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define trigPinL 2
#define echoPinL 3
#define trigPinR 6
#define echoPinR 7
#define Buzzer 5
#define SD_ChipSelectPin 4 // using digital pin 4 for SPI chip select
TMRpcm tmrpcm; // create an object for use in this sketch
bool flag = false;
// initialize the LCD
‘LiquidCrystal_I2C::begin()’;
lcd.backlight();
pinMode( Buzzer, OUTPUT );
pinMode( trigPinL, OUTPUT );
pinMode( echoPinL, INPUT );
pinMode( trigPinR, OUTPUT );
pinMode( echoPinR, INPUT );
digitalWrite(Buzzer, HIGH);
tmrpcm.speakerPin = 9; //5,6,11 or 46 on Mega, 9 on Uno, Nano, etc
if (!SD.begin(SD_ChipSelectPin))
flag = false;
flag = true;
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(“Object Detection”);
if (flag == true)
long duration, dis_L, dis_R;
digitalWrite(trigPinL, LOW);
delayMicroseconds(2);
digitalWrite(trigPinL, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPinL, HIGH);
dis_L = microsecondsTocentimeters(duration);
digitalWrite(trigPinR, LOW);
digitalWrite(trigPinR, HIGH);
duration = pulseIn(echoPinR, HIGH);
Serial.print(dis_L);
Serial.print("\t");
Serial.print(dis_R);
if ( dis_L < 20 || dis_R < 20)
lcd.setCursor(0, 1);
lcd.print("CAUTION !!! ");
digitalWrite(Buzzer, LOW);
delay(800);
lcd.print(“TOO NEAR”);
else if (dis_L >= 20 && dis_L < 30)
tmrpcm.play(“10.wav”);
lcd.print("20cm left ");
delay(3000);
else if (dis_R >= 20 && dis_R < 30)
tmrpcm.play(“11.wav”);
lcd.print("20cm right ");
delay(3000);
else if (dis_L >= 30 && dis_L < 40)
tmrpcm.play(“20.wav”);
lcd.print("30cm left ");
delay(3000);
else if (dis_R >= 30 && dis_R < 40)
tmrpcm.play(“21.wav”);
lcd.print("30cm right ");
delay(3000);
else if (dis_L >= 40 && dis_L < 50)
tmrpcm.play(“30.wav”);
lcd.print("40cm left ");
delay(3000);
else if (dis_R >= 40 && dis_R < 50)
tmrpcm.play(“31.wav”);
lcd.print("40cm right ");
delay(3000);
else if (dis_L >= 50 && dis_L < 60)
tmrpcm.play(“40.wav”);
lcd.print("50cm left ");
delay(3000);
else if (dis_R >= 50 && dis_R < 60)
tmrpcm.play(“41.wav”);
lcd.print("50cm right ");
delay(3000);
else if (dis_L >= 60 && dis_L < 70)
tmrpcm.play(“50.wav”);
lcd.print("60cm left ");
delay(3000);
else if (dis_R >= 60 && dis_R < 70)
tmrpcm.play(“51.wav”);
lcd.print("60cm right ");
delay(3000);
else if (dis_L >= 70 && dis_L < 80)
tmrpcm.play(“60.wav”);
lcd.print("70cm left ");
delay(3000);
else if (dis_R >= 70 && dis_R < 80)
tmrpcm.play(“61.wav”);
lcd.print("70cm right ");
delay(3000);
else if (dis_L >= 80 && dis_L < 85)
tmrpcm.play(“70.wav”);
lcd.print("80cm left ");
delay(3000);
else if (dis_R >= 80 && dis_R < 85)
tmrpcm.play(“71.wav”);
lcd.print("80cm right ");
delay(3000);
lcd.print(“No object near”);
lcd.print(“Unsuccess init”);
lcd.print(“Please check SD”);
long microseconds To “Centimeters”(long microseconds)
return microseconds / 29 / 2;
here is my coding
Looking for this?
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
-jim lee
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Have you tried the NewPing library for the ultrasonic sensor?
It does most of the calculation for you,
Tom... :slight_smile:
Here's three lines from your code.
long microseconds To "Centimeters"(long microseconds)
Remember C++ is case-sensitive
And what's going on with that 3rd line there?
