Please help! Due date approaching quickly
I am getting this error from a code that was working 30 minutes ago. Please help!
Arduino: 1.8.10 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
HW10_fig12:165:3: error: 'lcd' does not name a type
lcd.setCursor(0,0);
HW10_fig12:166:3: error: 'lcd' does not name a type
lcd.write(pAngle);
HW10_fig12:169:3: error: 'Serial' does not name a type
Serial.println(pAngle);
HW10_fig12:170:1: error: expected declaration before '}' token
Multiple libraries were found for "LiquidCrystal.h"
Used: C:\Program
Multiple libraries were found for "Wire.h"
Used: C:\Program
Multiple libraries were found for "Servo.h"
Used: C:\Program
exit status 1
option enabled in File -> Preferences.
Can you at least show your code starting from the first #include to the first 5 lines of loop()?
Sounds like you didn’t instantiate the ‘lcd’ object.
In the Arduino IDE, use CTRL T to format your code then copy the complete sketch.
Use the </> button from the ‘reply menu’ to attach the copied sketch.
Here is my complete code.
#include<LiquidCrystal.h>
#include <Wire.h>
#include<Servo.h>
Servo m1;
LiquidCrystal lcd(7, 6, 9, 3, 11, 12);
const int SSPin = 10;
const int CS = 8;
long t;
const int xPot = A0;
const int m1Pin = 5;
int xVal, m1Val, x;
int minP = 1000, maxP = 2000;
// MPU Parameters
const int mpu = 0x68;
const int pwr = 0x6B;
const int grt = 0x1B;
const int art = 0x1C;
const int axH = 0x3B;
const int gxH = 0x43;
float ax, ay, az, at;
float gx, gxA;
float axA, ayA, azA;
float pG;
float pA;
float pAngle;
float as = 8192.00;
float gs = 131.00;
float limit = 2500.00;
// Time Parameters
float ts = 0.004;
float tL = 0.0;
float tc = 0.0;
float dt = 0.0;
// FO LPF/HPF Parameters
float fc = 1.0, h = 0.01;
float wc = 2 * PI * fc, a = 1 - wc * h, b = wc * h;
float pAf, pGf, pGL;
  lcd.begin(16, 2);
  //_____________SD shield
  //_________________motor
  Wire.begin();
  pinMode(m1Pin, OUTPUT);
  m1.attach(m1Pin, minP, maxP);
  // Setting MPU Parameters
  Wire.beginTransmission(mpu);
  Wire.write(pwr);
  Wire.write(0x00); //
  Wire.endTransmission();
  Wire.write(grt);
  Wire.write(0x00);
  Wire.write(art);
  Wire.write(0x08);
  // Calibrating Gyroscope
  for (int i = 0; i < limit; i++)
    Wire.write(gxH);
    Wire.requestFrom(mpu, 2);
    gx = Wire.read() << 8 | Wire.read();
    gx /= gs;
    gxA += gx;
  gxA /= limit;
  //___________
  //xVal = analogRead(xPot);
  //xVal = constrain(xVal, 0, 1023);
  m1Val = int(30);
  m1.write(m1Val);
  Serial.println(m1Val);
  Serial.print("\t");
  tc = millis() / 1000.00;
  dt = tc - tL;
  if (dt >= ts)
    // Gyroscope Angle
    Wire.write(gxH);
    gx /= gs;
    gx -= gxA;
    pG += gx * dt;
    pGf = a * pGf + pG - pGL;
    pGL = pG;
    tL = tc;
    // Accelerometer Angle
    Wire.write(axH);
    Wire.requestFrom(mpu, 6);
    ax = Wire.read() << 8 | Wire.read();
    ay = Wire.read() << 8 | Wire.read();
    az = Wire.read() << 8 | Wire.read();
    ax /= as;
    ay /= as;
    az /= as;
    at = sqrt(ax * ax + ay * ay + az * az);
    pA = asin(ay / at) * 180.0 / PI;
    pA += 0.1;
    pAf = a * pAf + b * pA;
    // Complimentary Filter
    pAngle = pAf + pGf;
  //_________SD____
//_____LCD____
lcd.setCursor(0, 0);
lcd.write(pAngle);
//Serial.print(pA); Serial.print("\t");
//Serial.print(pG); Serial.print("\t");
You've got orphan code at the end of loop:
    //_____LCD____
    lcd.write(pAngle);
The top brace in this snippet closes loop. Everything below it is an orphan.
Wow I feel stupid, I checked for this at least 3 times.... Thank you so much
