Please Help for this code.
Hi guys.
I need to add direction button and start-stop button for this code in the below. I am using 4 wire bipolar and arduino uno+motor shield any one can help please. Thank you.
Hi every one.
I need to add direction button and start-stop button any one can help please?
for this code
Motor Shield Stepper Demo
by Randy Sarafan
For more information see:
http://www.instructables.com/id/Arduino-Motor-Shield-Tutorial/
int delaylegnth = 30;
  //establish motor direction toggle pins
  pinMode(12, OUTPUT); //CH A -- HIGH = forwards and LOW = backwards???
  pinMode(13, OUTPUT); //CH B -- HIGH = forwards and LOW = backwards???
  //establish motor brake pins
  pinMode(9, OUTPUT); //brake (disable) CH A
  pinMode(8, OUTPUT); //brake (disable) CH B
void loop(){
  digitalWrite(9, LOW);  //ENABLE CH A
  digitalWrite(8, HIGH); //DISABLE CH B
  digitalWrite(12, HIGH);   //Sets direction of CH A
  analogWrite(3, 1023);   //Moves CH A
  delay(delaylegnth);
  digitalWrite(9, HIGH);  //DISABLE CH A
  digitalWrite(8, LOW); //ENABLE CH B
  digitalWrite(13, LOW);   //Sets direction of CH B
  analogWrite(11, 1023);   //Moves CH B
  delay(delaylegnth);
  digitalWrite(12, LOW);   //Sets direction of CH A
  delay(delaylegnth);
  digitalWrite(13, HIGH);   //Sets direction of CH B
  delay(delaylegnth);
Moderator edit: Code tags added. sp. “length”
// establish switch input pins
can you write a little bit more please.
i am not good with writing codes. this code you write i insert before my original one and where i need to write rest of it? its kind of like this?
by Randy Sarafan
void loop(){
  delay(delaylegnth);
  delay(delaylegnth);
  delay(delaylegnth);
  delay(delaylegnth);
You need to start posting code between code tags.
Use the # icon on the editor's toolbar, then taste your code between the tags that appear.
You can go back to your previous posts, click on "modify", highlight the code, then click on the # icon.
Then click "save"
by Randy Sarafan
void loop(){
  delay(delaylegnth);
  delay(delaylegnth);
  delay(delaylegnth);
  delay(delaylegnth);
Have you looked at, and more importantly, worked through, any of the examples that came with the IDE?
I am trying but i get Confucius a lot. i been looking examples and playing around since last night till in the morning 5am wake up couple hours ago and still trying to figure it out. this was the only my last option to get resolve the my problem. Sorry for taking your time.
IDE
File/Examples/Digital/State Change Detection
