OK, I'm making some headway. It samples and writes to the SD card in 8ms intervals, or about 120 writes per second. It saves the time in Milliseconds, x axis, y axis, z axis, and also converts to G's for the x,y, and z.
The files it saves have a weird naming convention at the end for some unknown reason. All you have to do is change the .0*T to .txt or .csv and you can open it in a comma delineated spread sheet.
Here's the working code. Do with it as you please. It is just the sample code for the spark fun shields that has been mutilated, and sewn back together with tid bits from other code found around the net. I hope this helps other people just starting out like me. Also, I'm sure it's not the most efficient code, so if someone wants to play with and refine it, I'm sure others in the community would appreciate your efforts.
// Sonny Schade 04/15/2014
// Accelerometer Project using SparkFun ADXL345 and SD Data Logger Breakout boards
// Both Sheilds communicating over SPI
// SD Card uses Pin 8 by default for SS/CS Pin (Spark Fun Board)
// ADXL345 using Pin 10 for CS pin but you can use another digital pin if you choose
// This code was created by mutilating and sewing together code from sample code and other people's projects
// so feel free to do the same to this one, I hope this helps someone starting out.
// Include the relevant libraries provided with the Arduino
#include <SPI.h>
#include <SD.h>
// place holder for a large number
unsigned long time; // called it "time"
//Factors to change the data output by the accelerometer from raw data to G forces
double g=0.0039; //+/- 2g Make sure this matches the writeRegister Data Format on line 91!
//double g=0.0078; //+/- 4g
//double g=0.016; //+/- 8g
//double g=0.031; //+/- 16g
#define SYNC_INTERVAL 10000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
// Assign the ADXL345 CS pin to Pin 10 ** make this whatever digital pin you chose to use**
int CS=10;
//This is a list of some of the registers available on the ADXL345.
//To learn more about these and the rest of the registers on the ADXL345, read the datasheet!
char POWER_CTL = 0x2D; //Power Control Register
char DATA_FORMAT = 0x31;
char DATAX0 = 0x32; //X-Axis Data 0
char DATAX1 = 0x33; //X-Axis Data 1
char DATAY0 = 0x34; //Y-Axis Data 0
char DATAY1 = 0x35; //Y-Axis Data 1
char DATAZ0 = 0x36; //Z-Axis Data 0
char DATAZ1 = 0x37; //Z-Axis Data 1
char BW_RATE = 0x2C; //Sampling Rate
//This buffer will hold values read from the ADXL345 registers.
char values[10];
//Initalize variables
int x,y,z;
int i;
double xg,yg,zg;
double totals[3];
File myFile;
void setup(){
//Initiate an SPI communication instance.
SPI.begin();
Serial.begin(38400);
//Set up the Chip Select pin for the SD card to be an output from the Arduino.
pinMode(8, OUTPUT);
//Set chip select for ADXL345 to be output from Arduino.
pinMode(CS, OUTPUT);
//Set the CS Pin for the accelerometer high so that the ADXL345 and SD card won't be trying to talk at same time.
digitalWrite(CS, HIGH);
//Initialize the SD card
if (!SD.begin(8)) { // the (8) is the CS pin you chose to use, on my sheild that pin is hardwired to "8"
return;
// create a new file
// starts with Crash00, and next one would be Crash01
char filename[] = "Crash.txt";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
myFile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
//Print header to file
myFile.println("Time in MilliSeconds,X_Axis,Y_Axis,Z_Axis, X_G's,Y_G's,Z_G's");
//Configure the SPI connection for the ADXL345.
SPI.setDataMode(SPI_MODE3);
//Before communication starts, the Chip Select pin needs to be set high.
//Put the ADXL345 into +/- 4G range by writing the value 0x01 to the DATA_FORMAT register.
writeRegister(DATA_FORMAT, 0x00);//0x00 +/- 2G, 0x01 +/- 4G. 0x10 +/- 8G,0x11 +/-16G
//Put the ADXL345 into Measurement Mode by writing 0x08 to the POWER_CTL register.
writeRegister(POWER_CTL, 0x08); //Measurement mode
//Try and change sampling rate
writeRegister(BW_RATE, 0x0D);
void loop(){
//Count Milliseconds from time Arduino powered on
time = millis();
//Reading 6 bytes of data starting at register DATAX0 will retrieve the x,y and z acceleration values from the ADXL345.
//The results of the read operation will get stored to the values[] buffer.
readRegister(DATAX0, 6, values);
//The ADXL345 gives 10-bit acceleration values, but they are stored as bytes (8-bits). To get the full value, two bytes must be combined for each axis.
//The X value is stored in values[0] and values[1].
x = ((int)values[1]<<8)|(int)values[0];
//The Y value is stored in values[2] and values[3].
y = ((int)values[3]<<8)|(int)values[2];
//The Z value is stored in values[4] and values[5].
z = ((int)values[5]<<8)|(int)values[4];
//Convert raw data to g values
xg=x*g;
yg=y*g;
zg=z*g;
//Store g values in an array
totals[0] = xg;
totals[1] = yg;
totals[2] = zg;
// log time
myFile.print(time);
myFile.print(',');
//Log accelerations
myFile.print(x);
myFile.print(',');
myFile.print(y);
myFile.print(',');
myFile.print(z);
myFile.print(',');
for (i = 0; i < 3; i = i + 1) {
myFile.print(totals[i]);
myFile.print(',');
// Open the serial monitor to see if it's working, select a baud rate of 38400, only displays milliseconds and G's
Serial.print(time);
Serial.print(',');
Serial.print(totals[i]);
Serial.print(',');
myFile.println();
// Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
// which uses a bunch of power and takes time
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();
// flush the system
myFile.flush();
// delay to help clear some of the noise
// delayMicroseconds(2);
} //END OF LOOP!!!!!
//This function will write a value to a register on the ADXL345.
//Parameters:
// char registerAddress - The register to write a value to
// char value - The value to be written to the specified register.
void writeRegister(char registerAddress, char value){
//Set Chip Select pin low to signal the beginning of an SPI packet.
digitalWrite(CS, LOW);
//Transfer the register address over SPI.
SPI.transfer(registerAddress);
//Transfer the desired register value over SPI.
SPI.transfer(value);
//Set the Chip Select pin high to signal the end of an SPI packet.
//This function will read a certain number of registers starting from a specified address and store their values in a buffer.
//Parameters:
// char registerAddress - The register addresse to start the read sequence from.
// int numBytes - The number of registers that should be read.
// char * values - A pointer to a buffer where the results of the operation should be stored.
void readRegister(char registerAddress, int numBytes, char * values){
//Since we're performing a read operation, the most significant bit of the register address should be set.
char address = 0x80 | registerAddress;
//If we're doing a multi-byte read, bit 6 needs to be set as well.
if(numBytes > 1)address = address | 0x40;
//Set the Chip select pin low to start an SPI packet.
//Transfer the starting register address that needs to be read.
SPI.transfer(address);
//Continue to read registers until we've read the number specified, storing the results to the input buffer.
for(int i=0; i<numBytes; i++){
values[i] = SPI.transfer(0x00);
//Set the Chips Select pin high to end the SPI packet.
