Please help implement communication protocol
Dear Sirs,
I'm trying to implement a communication protocol, called DALI is an open standard that is used for lighting (to vary the light output of an electronic ballast), is structured as follows: The communication speed is 1200 bit / sec.
Transmission: 19 bits:
1 start bit, 1 byte address, 1 byte of data, 2 stop bits.
Reception: 11 bits: 1 start bit, 1 byte of data, 2 stop bits.
My question is how could implement, as the serial communications uses 8 data bits. I'm lost if someone could help me appreciate it.
Thanks. Greetings.
You could start by having a look at the source of the software serial libraries. Transmission is your only concern - receive is fine using the hardware UART. Bit-banging can be fiddly, but the bit rate is low, although for 16 tx data bits, your timing will have to be spot-on - error cannot exceed about 4% per bit.
Just found this cross-posted in harware/interfacing.
How I hate cross-posters; they make me....cross >:(
Thank you very much,
I'm a bit lost appreciate the aid.
Stuck pufffff ...., do not know how to continue.
On the form of modulation of the wave, you can see it in the manual:
http://www.archenergy.com/lrp/lightingperf_standards/DALI%20V1_13.pdf
Thank you very much
Stop cross-posting, it just wastes time and makes the OP unpopular.
You won't like me when I'm cross.
ok sorry, but did not know
