Please help. Programming is wrong, but I do not know where to find and solve the error.
The mpu6050 detects the tilt and send by bluetooth (hc-05), to the car telling the movement that the car has to perform.
Command material:
Arduino NANO
HC-05 (Bluetooth)
MPU-6050
Voltage regulator
The sketch (Car command) is as follows:
#include<Wire.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
const int MPU=0x68; // I2C address of the MPU-6050
int AcX,AcY,AcZ;
void setup(){
//Comunicação com o acelerometro
Wire.begin();
Wire.beginTransmission(MPU);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // zero para wakes up MPU-6050)
Wire.endTransmission(true);
Serial.begin(9600); //Para Serial Terminal fazer debug e ler valores do acelerometro
mySerial.begin(38400); //para envio por Bluetooth
void loop(){
//leitura dos valores do modulo GY-521
Wire.write(0x3B); // register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU,14,true);
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
//compara os valores obtidos do acelerometro, executa a função pretendida
if ((AcX/1000)<-5) {Serial.println("Tras"); mySerial.print("b");} else
if ((AcX/1000)>5) {Serial.println("Frente"); mySerial.print("f");} else
if ((AcZ/1000)<-5) {Serial.println("Esquerda"); mySerial.print("l");} else
if ((AcZ/1000)>5) {Serial.println("Direita"); mySerial.print("r");} else mySerial.print("S");
delay(5);
//debug
// Serial.print(AcY/1000);
// Serial.print(" ");
// Serial.print(AcX/1000);
// Serial.println(AcZ/1000);
// delay(1000);
Car material:
Arduino UNO
Driver Motor Ponte H L298N
HC-05
And the sketch (car) is as follows:
// Portas para comunicação RX, TX PARA O ARDUIN
char state; //para guardar o valor recebido por bluetooth
///////declaração de saidas para os reles para controlo de mov de motores dc /
int MTR0 = 2; //saida para o relé 0
int MTR1 = 3; //saida para o relé 1
int MTR2 = 7; //saida para o relé 2
int MTR3 = 8; //saida para o relé 3
// inicializa as portas Serial para o terminal e para o bluetooth para iniciar
pinMode(MTR0, OUTPUT);
pinMode(MTR1, OUTPUT);
pinMode(MTR2, OUTPUT);
pinMode(MTR3, OUTPUT);
// declara o estado inicial das portas de saida
digitalWrite(MTR0,HIGH);
digitalWrite(MTR1,HIGH);
digitalWrite(MTR2,HIGH);
digitalWrite(MTR3,HIGH); }
if (Serial.available()) {
// SE comunicaçao disponivel
state = Serial.read();// le o valor recebido pelo bluetooth,
// direita /////////////////////////////////////////
if (state == 'F' || state == 'f') {
digitalWrite(MTR0,LOW);
digitalWrite(MTR3,LOW); }
// esquerda /////////////////////////////////////////
if (state == 'B' || state == 'b') {
digitalWrite(MTR1,LOW);
digitalWrite(MTR2,LOW);
// frente /////////////////////////////////////////
if (state == 'R' || state == 'r') {
// tras /////////////////////////////////////
if (state == 'L' || state == 'l') {
// PARAR/////////////////////////////////////////
if (state == 'S' || state == 'w') {
delay(100);
