I need help with just programming a single avr microcontroller ATtiny85. But it keep giving me this error when I simply try to burn a bootloader. It has been many hours trying and failing to get this to work and I am tempted to just take hammer to it. All the connections are correct and none of connections are crossing over or broken or anything.
I am using an Arduino MKR 1300 WAN as the programmer and the ATTinyCore library. Also, the microcontroller was new and was purchased today. Please if you can help, I would appreciate it.
Log Below:
Arduino: 1.8.5 (Windows 10), Board: "ATtiny25/45/85, Disabled, CPU, ATtiny85, 8 MHz (internal), EEPROM retained, B.O.D. Disabled"
C:\Users\Regan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Regan\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.2.2/avrdude.conf -v -pattiny85 -carduino -PCOM3 -b19200 -e -Uefuse:w:0xFF:m -Uhfuse:w:0b11010111:m -Ulfuse:w:0xE2:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg WunschSystem wide configuration file is "C:\Users\Regan\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.2.2/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 19200
Setting bit clk period : 5.0
AVR Part : ATtiny85
Chip Erase delay : 400000 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 12 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 12 32 0 yes 8192 64 128 30000 30000 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 usavrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x000000 (retrying)
Error while burning bootloader.
Reading | ################################################## | 100% 0.00savrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.avrdude done. Thank you.
option enabled in File -> Preferences.
