Please help me about code PZEM004Tv30
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
#include <PZEM004Tv30.h>
#include <time.h>
// Config WiFi
#define WIFI_SSID     "bbt_2.4G"
#define WIFI_PASSWORD "BMUi2509"
// Config Firebase
#define FIREBASE_HOST "https://electric-67d28.firebaseio.com/"
#define FIREBASE_AUTH "electric-67d28.firebaseapp.com"
#ifndef min
#define min(a,b) ((a)<(b)?(a):(b))
#endif
float calBill(float Unit, float ft, bool over_150_Unit_per_month = false) ;
// Config time
int timezone = 7;
// Config bill
#define FIX_FT -15.90
char ntp_server1[20] = "ntp.ku.ac.th";
char ntp_server2[20] = "fw.eng.ku.ac.th";
char ntp_server3[20] = "time.uni.net.th";
int dst = 0;
unsigned long lastUpdateEnergy = 0, lastUpdateFirebase = 0;
float Volt, Amp, Power;
unsigned long Energy = 0;
PZEM004Tv30 pzem(D7,D6);  // (RX,TX) connect to TX,RX of PZEM
IPAddress ip(192, 168, 1, 1);
  pzem.setAddress(ip);
  while (!pzem.setAddress(ip)) {
    Serial.println("Connecting to PZEM...");
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("connecting");
    Serial.print(".");
  Serial.print("connected: ");
  configTime(timezone * 3600, dst, ntp_server1, ntp_server2, ntp_server3);
  Serial.println("Waiting for time");
  while (!time(nullptr)) {
    Serial.print(".");
  Serial.println("Now: " + getTime());
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
  if ((millis() - lastUpdateEnergy) >= 1000) {
    lastUpdateEnergy = millis();
    unsigned long startTime = millis();
    Volt = pzem.voltage(ip);
    Volt = Volt > 0 ? Volt : 0;
    Amp = pzem.current(ip);
    Amp = Amp > 0 ? Amp : 0;
    Power = Volt * Amp;
    Energy += Power;
    /*Serial.print("Load time: ");
    Serial.print(millis() - startTime);
    Serial.println("ms");
    Serial.println("Voltage: " + String(Volt, 2));
    Serial.println("Current: " + String(Amp, 2));
    Serial.println("Power: " + String(Power, 2));
    Serial.println("Energy: " + String(Energy));
    Serial.println("--------------------");
  time_t now = time(nullptr);
  struct tm* nowTime = localtime(&now);
  if ((nowTime->tm_sec % 30) == 0) {
    lastUpdateFirebase = millis();
    StaticJsonBuffer<200> jsonBuffer;
    JsonObject& root = jsonBuffer.createObject();
    root["volt"] = Volt;
    root["amp"] = Amp;
    root["time"] = getTime();
    String name = Firebase.push("/logPower", root);
    // handle error
    if (Firebase.failed()) {
      Serial.print("pushing failed:");
      Serial.println(Firebase.error());
      return;
    Serial.print("pushed: /logPower/");
    Serial.println(name);
    Firebase.setInt("/energy", Energy);
      return;
    Firebase.setFloat("/amount", calBill(Energy / 1000, FIX_FT, false));
      return;
  delay(0); // Disable WDT
String getTime() {
  struct tm* newtime = localtime(&now);
  String tmpNow = "";
  tmpNow += String(newtime->tm_year + 1900);
  tmpNow += "-";
  tmpNow += String(newtime->tm_mon + 1);
  tmpNow += "-";
  tmpNow += String(newtime->tm_mday);
  tmpNow += " ";
  tmpNow += String(newtime->tm_hour);
  tmpNow += ":";
  tmpNow += String(newtime->tm_min);
  tmpNow += ":";
  tmpNow += String(newtime->tm_sec);
  return tmpNow;
float calBill(float Unit, float ft, bool over_150_Unit_per_month) {
  float Service = over_150_Unit_per_month ? 38.22 : 8.19;
  float total = 0;
  if (!over_150_Unit_per_month) {
    float Rate15 = 2.3488;
    float Rate25 = 2.9882;
    float Rate35 = 3.2405;
    float Rate100 = 3.6237;
    float Rate150 = 3.7171;
    float Rate400 = 4.2218;
    float RateMore400 = 4.4217;
    if (Unit >= 6) total += min(Unit, 15) * Rate15;
    if (Unit >= 16) total += min(Unit - 15, 10) * Rate25;
    if (Unit >= 26) total += min(Unit - 25, 10) * Rate35;
    if (Unit >= 36) total += min(Unit - 35, 65) * Rate100;
    if (Unit >= 101) total += min(Unit - 100, 50) * Rate150;
    if (Unit >= 151) total += min(Unit - 150, 250) * Rate400;
    if (Unit >= 401) total += (Unit - 400) * RateMore400;
    float Rate150 = 3.2484;
    total += min(Unit, 150) * Rate150;
    if (Unit >= 151) total += min(Unit - 150, 150) * Rate400;
  total += Service;
  total += Unit * (ft / 100);
  total += total * 7 / 100;
  return total;
This Error
conversion from 'IPAddress' to 'uint8_t {aka unsigned char}' is ambiguous
